Klaros-Testmanagement 5.0.7 released - Klaros Test Management - Forum - Klaros Test Management
This maintenance release adds support for importing attachments for test cases and requirements via XML, adds customized report state management and improves the GitLab and Bugzilla integration.
Overall 6 improvements and 16 bug fixes are included in this release.
For more information about the new features in Klaros-Testmanagement 5.0, have a look at our forum Announcement Post.
Version 5.0.7 (28.01.2021)
Improvements
[KLAROS-4603] - Add the option to hide specific user defined reports for non-admin users
[KLAROS-4619] - Allow to import attachments for test cases and requirements via XML format
[KLAROS-4621] - Suppress empty journal entries in the history tab
[KLAROS-4630] - Add a GitLab icon to the issue details page when a GitLab issue is shown
[KLAROS-4631] - Fix font size for GitLab comments on the issue details page
[KLAROS-4639] - Allow to search for edited test segment steps in test cases
Bug Fixes
[KLAROS-4480] - Exception during background requirements synchronization
[KLAROS-4510] - Synchronizing a single requirement from the requirement details page activates the save/cancel buttons
[KLAROS-4579] - It is not possible to import an XML project backup that references an RMS if an RMS is already active on the Klaros instance
[KLAROS-4601] - Error storing Bugzilla custom datetime instances
[KLAROS-4605] - Rejecting a test case review leads to an exception
[KLAROS-4608] - Newlines are stripped from report model instances in multiline fields of plain text format projects
[KLAROS-4611] - Previous default value is shown when editing a default value of a custom report parameter
[KLAROS-4613] - Copying deleted predefined reports results in a NPE
[KLAROS-4616] - The notification events of a notification scheme are hidden until a manual refresh
[KLAROS-4624] - Deleting a freshly created notification event without prior saving leads to an exception
[KLAROS-4625] - Missing indices for test step large fields
[KLAROS-4627] - When no project is selected existing report templates are hidden from the report templates page
[KLAROS-4628] - The Steps tab on the test case details page fails to load if the session has timed out
[KLAROS-4629] - Unable to edit enum report parameter values
[KLAROS-4632] - Import of projects from backup files linked to external requirement management systems fails
[KLAROS-4641] - No job assignee notification mails are sent when a job is created or updated from the job list page
Release Notes
Improvements
Bug Fixes
