Klaros-Testmanagement 5.0.0 released
We are happy to announce the availability of Klaros-Testmanagement 5.0.0.
Dashboard
Whats new?
Usability
  • Descriptions for test cases, test steps, etc. are now editable as rich text and may contain images
  • Table contents can be edited directly in the individual cells via mouse click
  • Frequently used functions can be triggered by keyboard shortcuts
  • List entries can be reordered by drag-and-drop
  • Table sorting by clicking on the corresponding column header
  • Bookmarks can be copied directly to the clipboard
Reporting
  • Dashboard contents can now be individually configured and saved. Individual dashboards can be defined as project presets and shared with other users
  • The predefined reports have been completely revised and new reports have been added
  • The diagram display has been significantly accelerated by asynchronous loading
  • Dashboard diagrams can be exported as image files for further processing
  • Data tables can now also be exported in XML and PDF formats
  • Print pages optionally contain additional diagrams
Performance:
  • Database layout has been optimized and database access has been completely reworked
  • Batch transactions, especially for write operations, are now processed substantially faster
Installation
  • The Java runtime environment is now integrated and automatically installed.
  • Klaros uses the current LTS (Long Term Support) Java Runtime Environment Version 11
  • The Tomcat application server has been updated to the current version 9
Databases
  • The MySQL database is now also supported in version 8.
In total more than 13 bugs have been fixed, and 50 improvements as well as 15 new features have been added.
Release Notes
Version 5.0.0 (14.09.2020)
New Features
Improvements
Fixes
