Announcements
Klaros-Testmanagement 5.0.6 released
Answer
12/7/20 3:12 PM
This maintenance release significantly improves the user-experience for cross-project navigation and project switch behavior and extends
support for Jira and Mantis custom fields.
In addition the embedded Java Runtime Environment and Tomcat application server are updated to the newest versions available.
Overall 11 improvements and 12 bug fixes are included in this release.
Release Notes
Version 5.0.6 (07.12.2020)
Improvements
[KLAROS-4572] - On the Jobs by User page, clicking a username should open the respective user details page
[KLAROS-4573] - Include the test case estimated duration field in the Excel import interface
[KLAROS-4576] - Remove log message 'Cannot create Seam component, scope is not active: attachmentFileUploadBean(PAGE)' when uploading test case results via REST-API
[KLAROS-4577] - Update the Java-Runtime to OpenJDK 11.0.9.1+1
[KLAROS-4578] - Update Tomcat to version 9.0.40
[KLAROS-4580] - Use transitions when showing or hiding rich text fields
[KLAROS-4581] - Improve cross project navigation and project / iteration switch behavior
[KLAROS-4582] - When uploading multiple result files in a row, keep the last chosen result file format
[KLAROS-4583] - Improve cross project link traversal
[KLAROS-4594] - In issue management system selection menus, if a system doesn't have a project field, display its description instead
[KLAROS-4598] - Improve error reporting when an issue cannot be found in a Redmine issue tracker
Bug Fixes
[KLAROS-4574] - Broken rendering of test duration on the test case print page
[KLAROS-4575] - Jobs are not updated when uploading test results via the REST interface
[KLAROS-4585] - Email server setting SMTP authentication does not trigger setting authentication information
[KLAROS-4586] - Error creating the issue overview report when an issue does not contain a valid issue state
[KLAROS-4588] - Unable to directly execute a job in a different project than the one that is currently selected
[KLAROS-4590] - When changing the selected filter type in the filter panel, the value field is not updated accordingly
[KLAROS-4591] - New filter entries for a table should only be applied when pressing the 'Apply' button
[KLAROS-4592] - If more than one issue management is configured in a project, the list of available ims for linking issues during test execution is empty
[KLAROS-4593] - Manually refreshing the runner window while linking an issue throws an exception
[KLAROS-4595] - Missing options for Jira custom selection fields
[KLAROS-4596] - Missing custom fields when creating Mantis issues
[KLAROS-4599] - Impossible to store cutom date/dateTime field values for some issue management systems
0 (0 Votes)
