Klaros Test Management 5.0.4 released - Klaros Test Management - Forum - Klaros Test Management
We are pleased to announce the release of Klaros-Testmanagement 5.0.4!
This maintenance release adds improvements to the Jira and Bugzilla integration and fixes issues with accessing test case result pages, paging of tables with open filter preferences and dashboard report configurations.
In total, this release adds 9 improvements and resolves 16 issues. Existing users are encouraged to update.
Version 5.0.4 (30.10.2020)
Improvements
[KLAROS-1792] - Add a comment to issues in external issue management systems when linking them to test cases
[KLAROS-4515] - The 'evaluation' property of test cases should should be an enumeration value instead of plain text
[KLAROS-4521] - Misleading log entry "Unable to delete file: license.xml" when uploading a license file for the first time
[KLAROS-4526] - When assigning a job to a user, only users that can access the project should be presented
[KLAROS-4529] - Honor the suggested order of issue types from Jira when creating issues
[KLAROS-4532] - Show growl notifications in the test runner
[KLAROS-4537] - Enable smoother page transitions
[KLAROS-4538] - Improve Bugzilla custom field mapping
[KLAROS-4543] - Add support for usetargetmilestone=off setting in Bugzilla configurations
Bug Fixes
[KLAROS-4064] - Unable to create a backlink when linking existing issues to test cases
[KLAROS-4461] - Table content may not be visible when paging while the filter panel is opened
[KLAROS-4493] - Inconsistent behavior when subordinating jobs
[KLAROS-4499] - Creating a new revision of a requirement from the requirement details page will not link the test cases from the old revision to the new revision
[KLAROS-4524] - Sporadic error opening a test case result details page
[KLAROS-4530] - Missing new-line conversion for multi-line fields in print pages when plain-text text field format is active in a project
[KLAROS-4531] - Missing feedback in the UI when initially creating issues
[KLAROS-4533] - Test case related issues are not visible on the test case result detail page
[KLAROS-4534] - IndexOutOfBoundsException when navigating through list pages with an open filter panel
[KLAROS-4535] - Do not show the creation date of the message of the day when the message is empty
[KLAROS-4536] - Text box overflow with active plain text field mode in project
[KLAROS-4539] - Exception when trying to edit the configuration of an unsaved dashboard report
[KLAROS-4541] - Unable to select an iteration for newly created dashboard reports
[KLAROS-4542] - When selecting an iteration on the dashboard report configuration panel, the selected suts and envs show their internal id
[KLAROS-4544] - The description field is not properly stored in Bugzilla issues
[KLAROS-4545] - Exception when rendering a test environment overview report as a bar chart
Release Notes
Improvements
Bug Fixes
