Klaros-Testmanagement version 3.0.4 released - Klaros Test Management - Forum - Klaros Test Management
			We are very pleased, to finally announce the release of Klaros-Testmanagement version 3.0 after 3 months of hard work.
Klaros-Testmanagement now uses an improved database layout resulting in an drastically increased overall performance of the application. In addition to support of Redmine version 0.9, a new and polished look and feel has been added. Also a numerous amount of smaller improvements have been implemented.
In addition, Klaros-Testmanagement is now available in the commercially supported Enterprise Edition. Here we have been implemented more features that make the application an indispensable professional tool for test management.
In addition to an LDAP support for user authentication, particular attention was paid to the extension of the statistical and reporting. More reports, customizable reports and user definable fields for project-and sector requirements can cover your individual requirements. Data tables can also be exported to Excel for further processing. The dashboard is now configurable and contains additional reports.
We hope you enjoy this release.
Version 3.0.4 includes hot fixes for recent issues raised by our users. Thanks for your feedback!
The following issues have been fixed in this release:
Version 3.0.4 - 2010-08-13:
Version 3.0.3 - 2010-08-06:
New Features:
Version 3.0.2 - 2010-07-26:
[KLAROS-897] - The list of projects should have a sensible default sort order
Version 3.0.1 - 2010-07-19:
Version 3.0.0 - 2010-07-16:
New Features:
New Features:
New Features:
