Back
Setting up a domain to use for Klaros
Toggle
deployment domain virtualhost
Answer
5/25/19 11:29 AM
Good day.
12345678
<Host name="qa.example.com" debug="0" appBase="webapps/klaros-web"
        unpackWARs="false"
    xmlValidation="false" xmlNamespaceAware="false">
<Logger className="org.apache.catalina.logger.FileLogger"
directory="logs"  prefix="qa.example.com\_log." suffix=".txt" timestamp="true"/>
</Host>
1234
<?xml version='1.0' encoding='utf-8'?>
<Context displayName="qa.example.com" docBase="" path=""
workDir="work/Catalina/qa.example.com/_">
</Context>
After the restart, when I type in the URL http://qa.example.com:18080/ in the browser, I get:
This qa.example.com page can’t be foundNo webpage was found for the web address: http://qa.example.com:18080/HTTP ERROR 404========================ANY HELP IS MUCH APPRECIATED.
Thank you.
0 (0 Votes)
RE: Setting up a domain to use for Klaros
Answer
5/22/19 2:30 PM as a reply to Musa Haidari.
Hi Musa,
+1 (1 Vote)
Answer
5/22/19 9:02 PM as a reply to Musa Haidari.
Hello Musa,
+1 (1 Vote)
Answer
5/25/19 11:48 AM as a reply to Musa Haidari.
Dear team,
0 (0 Votes)
Answer
5/25/19 7:50 PM as a reply to Musa Haidari.
Hello Musa,
+1 (1 Vote)
Answer
5/26/19 12:29 PM as a reply to Musa Haidari.
0 (0 Votes)
