The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.8.0!
New features:
o A report to show details of a single or all test plans inside a project Issue: KLAROS-232. o Migration function to give an administrator the possiblity to migrate the database to the next version Issue: KLAROS-222.
o The description is not saved when creating an test plan. Issue: KLAROS-220.
Changes:
o Correct the padding and alignment of the data table columns Issue: KLAROS-225. o The fields for the environment and system under test on the import page should be drop down boxes. Issue: KLAROS-223. o Overwork the TestSeries in Klaros-Core to replace all string lists with object relations. Issue: KLAROS-219. o The order of the test run list for selecting a test report should reflect the indexed object Issue: KLAROS-179.
verit Informationssysteme GmbH is an independent software vendor focusing on tools for software quality management and software test automation, located in Kaiserslautern, Germany.
verit Informationssysteme GmbH 67657 Kaiserslautern Europaallee 10 Germany Phone: +49 631 520 840 00 Fax: +49 631 520 840 01
