Klaros-Testmanagement version 1.5.0 released
The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.5.0!
New features:
o A mechanism to easily switch betweeen community and demo version is needed. Issue: KLAROS-163.
o Add a new property to set the application URL manually Issue: KLAROS-149.
o Wrong label for Test Plan in Detail test Plan result Screen Issue: KLAROS-160.
o Klaros doesn't check if a JIRA issue exists before getting it from JIRA. Issue: KLAROS-157.
o Search Environment is not clean when change project Issue: KLAROS-155.
o Wrong number formatting in the project summary diagram Issue: KLAROS-133.
o Editing a newly created manager account leads to an exception Issue: KLAROS-129.
o A user in the role tester is not able to change his/her user settings Issue: KLAROS-128.
o The .war file generated by ant cannot create reports Issue: KLAROS-125.
o Resize the images of the manual Issue: KLAROS-124.
o The maven build deploys always into the HEAD instead to deploy into the folder of the checked out version Issue: KLAROS-122.
o There is the new entry 'Import/Export' in the navigation menu Issue: KLAROS-111.
o In Create Test Plan screen shouldn't be possible to Add the same test case many times Issue: KLAROS-99.
o Errors in the test plan execution Issue: KLAROS-79.
o Edit Test Case - The application is in English but the content of select items is in German Issue: KLAROS-75.
o JIRA Session timeouts are not handled correctly Issue: KLAROS-54.
Changes:
o Unneccessary display of the change password button Issue: KLAROS-143.
o Modify order of columns "Name" and "Test Plan" in Continue Test Plan Issue: KLAROS-142.
o The System should show a warning message that no project has been activated yet Issue: KLAROS-131.
o The SMTP Type setting on the E-Mail Configuration should be using a selection box Issue: KLAROS-130.
o The project description entry should be mandatory when creating a project. Issue: KLAROS-127.
o Improve the chapter 'Installation' and replace the copy&paste text Issue: KLAROS-113.
67657 Kaiserslautern
Europaallee 10
Germany
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
