Dependency between Testcases - Klaros Test Management - Forum - Klaros Test Management
Markus Nagel, modified 13 Years ago.
Youngling Posts: 5 Join Date: 6/26/12 Recent Posts
Hi all,
When trying out Claros I still got a question: Can I add dependencies between test cases only in the text box "dependencies"? Is that enough? I have entered the ID TC0002. When running the test case, the registration function did not affect the running of the test case. I have to at least be advised of dependencies. If there is no such possibility at Claros?
Thank you for info and help.
Regards, Markus
Regards, Markus
RE: Dependency between Testcases
Hi Markus,
the text box is the right location too add this dependency, yet it is a free-form text field with no semantics attached.
The tester is shown this field when a test case execution is started and has to act accordingly (e.g. "DO NOT ATTEMPT TO RUN THIS IF TC0006 HAS NOT SUCCEEDED").
Making this a formal dependency is currently out of reach of the application as the needed semantics may get out of hand quite quickly.
As a solution I would suggest placing dependent tests in test suites to be executed in sequence and add instructions as shown below.
Or am I missing something in your requirements?
