RE: Bugzilla issue/question: custom field support - Klaros Test Management - Forum - Klaros Test Management
Dutch Buckholz, modified 13 Years ago.
Youngling Posts: 10 Join Date: 4/18/12 Recent Posts
Hi all,
Suggestions?
Dutch
Edit to include more data:
<bz:cf_browser>
<Seq>
<li>---</li>
<li>IE</li>
<li>Firefox</li>
<li>Safari</li>
<li>Chrome</li>
</Seq>
</bz:cf_browser>
<bz:cf_casetype>
<Seq>
<li>Bug</li>
<li>Enhancement</li>
<li>Task</li>
<li>Doc</li>
<li>Prod Incident</li>
<li>---</li>
</Seq>
</bz:cf_casetype>
Suggestions?
Dutch
<bz:cf_browser>
<Seq>
<li>---</li>
<li>IE</li>
<li>Firefox</li>
<li>Safari</li>
<li>Chrome</li>
</Seq>
</bz:cf_browser>
<bz:cf_casetype>
<Seq>
<li>Bug</li>
<li>Task</li>
<li>Doc</li>
<li>---</li>
</Seq>
</bz:cf_casetype>
RE: Bugzilla issue/question: custom field support (Answer)
Hi Dutch,
Thanks again,
Dutch
Thanks again,
Dutch
Thanks for your patience - so many feature requests, so little time
Philippe A Couvignou, modified 12 Years ago.
Youngling Post: 1 Join Date: 11/30/12 Recent Posts
Thanks.
Thanks.
