RE: Bug under execute area - Klaros Test Management - Forum - Klaros Test Management
Probably I have found a bug under "execute" area.
I have some test environments (6 items).
I have made two test suite with two test cases added. I have set also 1 test environment for every test suite in the "define" area.
When I change menu, under "execute" area, I select a test suite to execute but klaros don't consider the test env. that I have selected before.
Thanks.
Regards.
Thanks.
Regards.
Well spotted. Confirmed and tracked as KLAROS-1576 - Test suite execute does no longer honor the assigned test suite.
This has now been fixed towards version 3.5.4.
Thanks for submitting!
