RE: Error under installation - Klaros Test Management - Forum - Klaros Test Management
Gianmaria Gai, modified 12 Years ago.
Install was successful
Thanks.
Thanks.
Ok thanks,
following your guide:
Any idea?
Any idea?
Installation DONE.
Thanks.
insted of
Thanks.
insted of
Thanks for spotting!
Cheers,
Cheers,
