RE: Bugzilla 4.2
Kai Lemcke, modified 13 Years ago.
Bugzilla 4.2
Youngling Post: 1 Join Date: 4/3/12 Recent Posts
ich versuche die aktuelle Community Version mit einem Bugzilla 4.2 zu verbinden.
Der Test beim Anlegen eines Issue Management Systems funktioniert,
beim Anlegen eines Issues bekomme ich aber immer diesen Fehler.
Unable to save the issue: Security token error (unknown reason because Bugzilla < 4.0 was used) occurred during submission to http://localhost:8080. Synchronize task and re-submit changes.
RE: Bugzilla 4.2
Hi Kai,
thanks for your feedback. You are most probably stumbling over https://bugs.eclipse.org/bugs/show_bug.cgi?id=365959 which is caused by a not backward compatible change introduced in Bugzilla 4.2.
Mylyn 3.7 has been released about a week ago, we will update the implementation in the next maintenance release.
I will add an answer here as soon as this is available.
RE: Bugzilla 4.2
Klaros-Testmanagement 3.5.4 is now available and adds support for Bugzilla 4.2.
Please let us know if you have any more problems.
