RE: Update from 3.4.10 to 3.5.1 does not work - Klaros Test Management - Forum - Klaros Test Management
Good Morning,
i try to update from 3.4.10 to 3.5.1 with PostgreSQL-DB.
Update seems to work. I can see the new Versionnumber on the login page.
I try to update the database with an administrator and this also seems to work.
I saw the login-page and try to login an user and nothing happens.
After a while i saw that text at the webbrowser:
I try to open Klaros-Loginpage in an other browser IE and watch the catalina.out...please see attached.
Fehlerhaftes Gateway!
Der Proxy-Server erhielt eine fehlerhafte Antwort eines übergeordneten Servers oder Proxies.
The proxy server could not handle the request POST /klaros-web/block/send-receive-updates.
Sofern Sie dies für eine Fehlfunktion des Servers halten, informieren Sie bitte den Webmaster hierüber.
Error 502
klaros.e-dict.net
Mon Mar 12 08:38:22 2012
Apache/2.2.10 (Linux/SUSE)
Error 502
klaros.e-dict.net
Hi Sven,
you are running into a seam internal timeout during login. I see two potential reasons for this:
1. During migration several database indices are getting created, which might prevent the login method to finish in a timely matter
2. You are running on resource limited hardware (see below)
Your startup times are quite high indicating that this is not the most powerful hardware you are using, is this right?
Does your problem persist after a tomcat restart?
Are you experiencing system load on the database server when this error occurs?
I see no apparent reason for a persisting problem here.
INFO: Server startup in 91275 ms
out klaros-server is a vmware, so i think this is the reason for a long starttime.
I update again from 3.4.10 to 3.5.1:
Stop Klaros
I delete before updating the webapps-klaros folder.
I start the installer
All works fine
Open the loginpage, see the page for db-update
Enter the admin name...
see this in log:
I
After a while i have seen the normal klaros login page.
I try to login with my user... after pressing enter i saw the wait-cursor of the browser, after 5 Minutes doing nothing i press the relaod-Button and saw this in the catalina.out:
Now i try to stop klaros and all i see is this:
How could i resolve that problem?
Stop Klaros
All works fine
see this in log:
I
NFO: Server startup in 94002 ms
Mar 13, 2012 2:42:53 PM com.sun.faces.lifecycle.ELResolverInitPhaseListener populateFacesELResolverForJsp
2012-03-13 14:43:16: WARN, org.hibernate.util.JDBCExceptionReporter, http-18080-7 SQL Error: 0, SQLState: 42P07
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_executable_01" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_executable_02" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "idx_k_rel_ts_exec_02" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_case_result_01" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_case_result_02" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_run_01" already exists
2012-03-13 14:43:16: ERROR, org.hibernate.util.JDBCExceptionReporter, http-18080-7 ERROR: relation "cidx_k_test_run_02" already exists
2012-03-13 14:52:58: ERROR, com.icesoft.faces.facelets.D2DFaceletViewHandler, http-18080-8 Problem in renderResponse: javax.el.ELException: /pages/include/includeLogin.jspx @44,78 value="#{userHandler.username}": Error reading 'username' on type de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50
javax.faces.FacesException: javax.el.ELException: /pages/include/includeLogin.jspx @44,78 value="#{userHandler.username}": Error reading 'username' on type de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50
at javax.faces.component.UIOutput.getValue(UIOutput.java:187) ~[jsf-api-1.2_14.jar:1.2_14-b01-FCS]
at com.icesoft.faces.renderkit.dom_html_basic.BaseInputRenderer.getValue(BaseInputRenderer.java:36) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.renderkit.dom_html_basic.InputTextRenderer.encodeEnd(InputTextRenderer.java:43) ~[icefaces-1.8.2-1.jar:na]
at javax.faces.component.UIComponentBase.encodeEnd(UIComponentBase.java:861) ~[jsf-api-1.2_14.jar:1.2_14-b01-FCS]
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:370) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.renderkit.dom_html_basic.GridRenderer.encodeChildren(GridRenderer.java:208) ~[icefaces-1.8.2-1.jar:na]
at javax.faces.component.UIComponentBase.encodeChildren(UIComponentBase.java:837) ~[jsf-api-1.2_14.jar:1.2_14-b01-FCS]
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:358) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.renderkit.dom_html_basic.GroupRenderer.encodeChildren(GroupRenderer.java:96) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:365) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:492) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:497) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.facelets.D2DFaceletViewHandler.renderResponse(D2DFaceletViewHandler.java:282) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.application.D2DViewHandler.renderView(D2DViewHandler.java:159) [icefaces-1.8.2-1.jar:na]
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:110) [jsf-impl-1.2_14.jar:1.2_14-b01-FCS]
at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.render(LifecycleImpl.java:127) [LifecycleImpl.class:na]
at com.icesoft.faces.context.View$2$1.respond(View.java:48) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.webapp.http.servlet.ServletRequestResponse.respondWith(ServletRequestResponse.java:201) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.context.View$2.serve(View.java:77) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.context.View.servePage(View.java:149) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.webapp.http.core.MultiViewServer.service(MultiViewServer.java:67) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.webapp.http.common.ServerProxy.service(ServerProxy.java:11) [icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.webapp.http.servlet.MainSessionBoundServlet$4.service(MainSessionBoundServlet.java:149) [icefaces-1.8.2-1.jar:na]
at de.verit.klaros.web.servlet.ExceptionHandlingPersistentFacesServlet.service(ExceptionHandlingPersistentFacesServlet.java:53) [ExceptionHandlingPersistentFacesServlet.class:na]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java) [catalina.jar:6.0.33]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java) [catalina.jar:6.0.33]
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:185) [javamelody-core-1.34.0.jar:1.34.0]
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:159) [javamelody-core-1.34.0.jar:1.34.0]
at de.verit.klaros.web.beans.interceptor.TimingFilter.doFilter(TimingFilter.java:54) [TimingFilter.class:na]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java) [catalina.jar:6.0.33]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java) [catalina.jar:6.0.33]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java) [catalina.jar:6.0.33]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java) [catalina.jar:6.0.33]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java) [catalina.jar:6.0.33]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java) [catalina.jar:6.0.33]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java) [catalina.jar:6.0.33]
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java) [tomcat-coyote.jar:6.0.33]
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java) [tomcat-coyote.jar:6.0.33]
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java) [tomcat-coyote.jar:6.0.33]
at java.lang.Thread.run(Thread.java:662) [na:1.6.0_30]
Caused by: javax.el.ELException: /pages/include/includeLogin.jspx @44,78 value="#{userHandler.username}": Error reading 'username' on type de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50
at com.sun.facelets.el.TagValueExpression.getValue(TagValueExpression.java:76) ~[icefaces-facelets-1.8.2.jar:na]
at javax.faces.component.UIOutput.getValue(UIOutput.java:184) ~[jsf-api-1.2_14.jar:1.2_14-b01-FCS]
... 72 common frames omitted
Caused by: org.jboss.seam.core.LockTimeoutException: could not acquire lock on @Synchronized component: userHandler
at org.jboss.seam.core.SynchronizationInterceptor.aroundInvoke(SynchronizationInterceptor.java:41) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final]
at de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50.getUsername(UserHandler_$$_javassist_seam_50.java) ~[UserHandler.class:na]
at javax.el.BeanELResolver.getValue(BeanELResolver.java) ~[el-api.jar:2.1.FR]
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java) ~[el-api.jar:2.1.FR]
at com.sun.faces.el.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:72) ~[jsf-impl-1.2_14.jar:1.2_14-b01-FCS]
at org.jboss.el.parser.AstPropertySuffix.getValue(AstPropertySuffix.java:53) ~[jboss-el-1.0_02.CR5.jar:1.0_02.CR5]
at org.jboss.el.parser.AstValue.getValue(AstValue.java:67) ~[jboss-el-1.0_02.CR5.jar:1.0_02.CR5]
at org.jboss.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186) ~[jboss-el-1.0_02.CR5.jar:1.0_02.CR5]
at com.sun.facelets.el.TagValueExpression.getValue(TagValueExpression.java:71) ~[icefaces-facelets-1.8.2.jar:na]
... 73 common frames omitted
Mar 13, 2012 2:52:58 PM com.sun.faces.lifecycle.Phase doPhase
SEVERE: JSF1054: (Phase ID: RENDER_RESPONSE 6, View ID: /pages/login.jspx) Exception thrown during phase execution: javax.faces.event.PhaseEvent[source=com.sun.faces.lifecycle.LifecycleImpl@764e2ed9]
2012-03-13 14:52:58: ERROR, com.icesoft.faces.context.View, http-18080-8 Exception occured during rendering on http://klaros.e-dict.net/klaros-web/pages/login.seam?conversationId=2 [/pages/login.jspx]
javax.faces.FacesException: javax.faces.FacesException: javax.el.ELException: /pages/include/includeLogin.jspx @44,78 value="#{userHandler.username}": Error reading 'username' on type de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50
at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.render(LifecycleImpl.java:132) ~[LifecycleImpl.class:na]
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:19) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.context.View$2$1.respond(View.java:48) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.webapp.http.servlet.ServletRequestResponse.respondWith(ServletRequestResponse.java:201) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.context.View$2.serve(View.java:77) ~[icefaces-1.8.2-1.jar:na]
Caused by: javax.faces.FacesException: javax.el.ELException: /pages/include/includeLogin.jspx @44,78 value="#{userHandler.username}": Error reading 'username' on type de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_50
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:492) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:497) ~[icefaces-1.8.2-1.jar:na]
at com.icesoft.faces.application.D2DViewHandler.renderView(D2DViewHandler.java:159) ~[icefaces-1.8.2-1.jar:na]
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:110) ~[jsf-impl-1.2_14.jar:1.2_14-b01-FCS]
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139) ~[jsf-impl-1.2_14.jar:1.2_14-b01-FCS]
at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.render(LifecycleImpl.java:127) ~[LifecycleImpl.class:na]
... 36 common frames omitted
Mar 13, 2012 2:54:35 PM org.apache.coyote.http11.Http11Protocol pause
Mar 13, 2012 2:54:36 PM org.apache.catalina.core.StandardService stop
Mar 13, 2012 2:54:36 PM org.apache.catalina.core.StandardWrapper unload
INFO: Waiting for 3 instance(s) to be deallocated
Mar 13, 2012 2:54:37 PM org.apache.catalina.core.StandardWrapper unload
Mar 13, 2012 2:54:38 PM org.apache.catalina.core.StandardWrapper unload
i kill the process and start klaros again.
Now i can login, but it is slow, but i can work on it.
Jedi Council Member Posts: 777 Join Date: 2/12/09 Recent Posts...
This part is harmless, as the database indices have already been created before.
It looks like the shutdown never succeeded.
Is your postgreSQL Server co-located on the same VM?
Can you check the speed of your database and klaros filesystem access?
There must be something strange going on with your setup here. Maybe the postgres logs can shed some light on this?
Hello Sven,
we detected the root cause for the problems you have experienced. The 3.5.2 release fixes the lockups after successful migration.
OK, thanks i will try it out.
The Link to the release Notes are wrong, if you open it you see the release notes for 3.4.8 and not for 3.5.2
In your Notification-Email is a mistake. The url to that post ist wrong:
http://www.klaros-testmanagement.comhttp://www.klaros-testmanagement.com/forum/-/message_boards/message/90510
I have updated to 3.5.2 and it seems to work good.
Thank you
Thank you
