RE: Ubuntu Installation - Klaros Test Management - Forum - Klaros Test Management
I've been trying for the last little while to install Klaros on Ubuntu. The server never comes up. http://mysite.com:18080/klaros-web/ says connection timed out.
The logs don't show any errors.. so I'm not sure how to troubleshoot further.
About my setup:
I installed klaros on a VM of a Ubuntu minimal install (no GUI). I am accessing the web site from the VM's host windows PC. I used the klaros installation defaults and post installation I changed the hibernate.properties to switch the db to mysql. Klaros has successfully populated the database.
Here's some relevant information:
Any information would be useful. Thanks!
About my setup:
user@ubuntu10:~$ /srv/klaros/bin/catalina.sh version | |
Using CATALINA_BASE: /srv/klaros | |
Using CATALINA_HOME: /srv/klaros | |
Using CATALINA_TMPDIR: /srv/klaros/temp | |
Using JRE_HOME: /usr | |
Using CLASSPATH: /home/user/.klaros/resources:/srv/klaros/bin/bootstrap.jar | |
Server version: Apache Tomcat/6.0.33 | |
Server built: Aug 16 2011 02:16:34 | |
Server number: 6.0.33.0 | |
OS Name: Linux | |
OS Version: 2.6.32-24-server | |
Architecture: amd64 | |
JVM Version: 1.6.0_21-b06 | |
JVM Vendor: Sun Microsystems Inc. |
24-Feb-2012 12:29:19 PM org.apache.catalina.core.AprLifecycleListener init | |
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-sun-1.6.0.21/jre/lib/amd64/server:/usr/lib/jvm/java-6-sun-1.6.0.21/jre/lib/amd64:/usr/lib/jvm/java-6-sun-1.6.0.21/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib | |
24-Feb-2012 12:29:19 PM org.apache.coyote.http11.Http11Protocol init | |
INFO: Initializing Coyote HTTP/1.1 on http-18080 | |
24-Feb-2012 12:29:19 PM org.apache.catalina.startup.Catalina load | |
INFO: Initialization processed in 1593 ms | |
24-Feb-2012 12:29:20 PM org.apache.catalina.core.StandardService start | |
INFO: Starting service Catalina | |
24-Feb-2012 12:29:20 PM org.apache.catalina.core.StandardEngine start | |
INFO: Starting Servlet Engine: Apache Tomcat/6.0.33 | |
24-Feb-2012 12:29:20 PM org.apache.catalina.startup.HostConfig deployDescriptor | |
INFO: Deploying configuration descriptor manager.xml | |
INFO: Deploying configuration descriptor host-manager.xml | |
24-Feb-2012 12:29:20 PM org.apache.catalina.startup.HostConfig deployWAR | |
INFO: Deploying web application archive klaros-web.war | |
24-Feb-2012 12:29:24 PM org.apache.catalina.core.StandardContext addApplicationListener | |
INFO: The listener "com.icesoft.faces.util.event.servlet.ContextEventRepeater" is already configured for this context. The duplicate definition has been ignored. | |
24-Feb-2012 12:33:11 PM com.sun.faces.config.ConfigureListener contextInitialized | |
INFO: Initializing Mojarra (1.2_14-b01-FCS) for context '/klaros-web' | |
24-Feb-2012 12:33:40 PM org.apache.catalina.startup.HostConfig deployDirectory | |
INFO: Deploying web application directory ROOT | |
INFO: Deploying web application directory docs | |
INFO: Deploying web application directory examples | |
24-Feb-2012 12:33:44 PM org.apache.coyote.http11.Http11Protocol start | |
INFO: Starting Coyote HTTP/1.1 on http-18080 | |
24-Feb-2012 12:33:44 PM org.apache.jk.common.ChannelSocket init | |
INFO: JK: ajp13 listening on /0.0.0.0:18009 | |
24-Feb-2012 12:33:44 PM org.apache.jk.server.JkMain start | |
INFO: Jk running ID=0 time=0/154 config=null | |
24-Feb-2012 12:33:45 PM org.apache.catalina.startup.Catalina start | |
INFO: Server startup in 265768 ms |
G S, modified 13 Years ago.
RE: Ubuntu Installation (Answer)
Youngling Posts: 2 Join Date: 2/24/12 Recent Posts
I used the full Ubuntu-10.04x64 Server for my VM and Klaros works now.
I ran most of the setup through an SSH terminal but the Klaros setup was run from within the VM's GUI console to the Ubuntu GUI.
Incase anyone is our there struggling like I was here are the steps I too to install Klaros:
1. Download setup
2. Install Java
Check Version
3. Install Klaros
I ran this from within the Ubuntu GUI terminal.
Follow instructions here: http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.InstallationProcess.html
4. Stop Klaros, if you selected to start it.
5. (Reccomended-Optional) Switch Klaros Database
Install MySql:
Switch Klaros Database:
Replace file contents with (replace mysql credentials with yours)
7. Start Klaros
8. Test in browser
Navigate to: http://localhost:18080/klaros-web/
9. Check if Klaros has populated mysql
If you switched the database in step 5
Thats It!
1. Download setup
wget http://www.klaros-testmanagement.com/files/Klaros-Setup.jar |
2. Install Java
sudo add-apt-repository ppa:sun-java-community-team/sun-java6 | |
sudo apt-get update | |
sudo apt-get install sun-java6-bin sun-java6-jre sun-java6-jdk |
Check Version
java -version | |
java version "1.6.0_21" | |
Java(TM) SE Runtime Environment (build 1.6.0_21-b06) | |
Java HotSpot(TM) 64-Bit Server VM (build 17.0-b16, mixed mode) |
3. Install Klaros
java -jar Klaros-Setup.jar |
/path_to_klaros/bin/catalina.sh stop |
Install MySql:
sudo apt-get install mysql-server mysql-client | |
mysqladmin create klaros or mysqladmin create -uroot -p<your_password> klaros |
vi ~.klaros/hibernate.properties |
hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect | |
hibernate.connection.url=jdbc:mysql://localhost:3306/klaros | |
7. Start Klaros
/path_to_klaros/bin/catalina.sh start |
8. Test in browser
mysql klaros -uroot -p |
mysql> show tables |
Thats It!
Jedi Council Member Posts: 776 Join Date: 2/12/09 Recent Posts
Hi G.,
Thanks for providing this excellent step by step description!
As I can find nothing suspicious in the logs of your first post, did you pinpoint what exactly prevented the startup there?
Oh and just in case - did you notice that the -console option is available for a GUI-less installation?
Have a nice weekend,
