paralel save leads to DataIntegrityViolationException - Klaros Test Management - Forum - Klaros Test Management
Attila Erdei, modified 13 Years ago.
Youngling Posts: 2 Join Date: 1/4/12 Recent Posts
Hey!
We recently use your software (Community Edition 3.4.8 - Build 580), and found some bugs. This is one of them.
When 2 different users tries to save simultaneously, one of them gets an exception, but the save happens in the background. The 2 users edit different things (TCs). Similar incident occured when 2 users edited testsuites. The actual exceptions:
Testcase update:
#{testCaseHandler.updateTestCase}: org.springframework.dao.DataIntegrityViolationException: Could not execute JDBC batch update; nested exception is org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(null:-1)
Caused by: #{testCaseHandler.updateTestCase}: org.springframework.dao.DataIntegrityViolationException: Could not execute JDBC batch update; nested exception is org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
Caused by: org.springframework.dao.DataIntegrityViolationException: Could not execute JDBC batch update; nested exception is org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
at org.springframework.orm.hibernate3.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:636)
at org.springframework.orm.hibernate3.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:412)
at org.springframework.orm.hibernate3.HibernateTemplate.flush(HibernateTemplate.java:890)
at de.verit.klaros.core.dao.hibernate.HibernateDAO.flush(HibernateDAO.java:92)
at de.verit.klaros.web.handler.TestCaseHandler.updateTestCase(TestCaseHandler.java:2035)
at sun.reflect.GeneratedMethodAccessor2443.invoke(null:-1)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null:-1)
at java.lang.reflect.Method.invoke(null:-1)
at de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_58.updateTestCase(TestCaseHandler_$$_javassist_seam_58.java:-1)
at sun.reflect.NativeMethodAccessorImpl.invoke0(null:-2)
at sun.reflect.NativeMethodAccessorImpl.invoke(null:-1)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:348)
at org.jboss.el.parser.AstPropertySuffix.invoke(AstPropertySuffix.java:58)
Caused by: Could not execute JDBC batch update; nested exception is org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:96)
at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:66)
at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:275)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:262)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:182)
at org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:321)
at org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1208)
at sun.reflect.GeneratedMethodAccessor895.invoke(null:-1)
at org.jboss.seam.persistence.HibernateSessionInvocationHandler.invoke(HibernateSessionInvocationHandler.java:82)
at $Proxy70.flush(null:-1)
at org.jboss.seam.ioc.spring.SeamManagedSessionFactoryBean$SeamManagedSessionHandler.invoke(SeamManagedSessionFactoryBean.java:300)
at $Proxy71.flush(null:-1)
at org.springframework.orm.hibernate3.HibernateTemplate$28.doInHibernate(HibernateTemplate.java:892)
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:419)
at com.mysql.jdbc.PreparedStatement.executeBatchSerially(PreparedStatement.java:2024)
at com.mysql.jdbc.PreparedStatement.executeBatch(PreparedStatement.java:1449)
at com.mchange.v2.c3p0.impl.NewProxyPreparedStatement.executeBatch(NewProxyPreparedStatement.java:1723)
at org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBatcher.java:70)
at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:268)
Caused by: Duplicate entry '5ed1f5fa-66d6-40e5-949c-7b9cb66deae3-5' for key 'PRIMARY'
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(null:-2)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(null:-1)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(null:-1)
at java.lang.reflect.Constructor.newInstance(null:-1)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1039)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3597)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3529)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1990)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2151)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2625)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2119)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2415)
at com.mysql.jdbc.PreparedStatement.executeBatchSerially(PreparedStatement.java:1976)
Testsuite update:
#{maintainTestPlanAssignBean.updateTestPlans}: org.springframework.dao.DataIntegrityViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]; nested exception is org.hibernate.exception.ConstraintViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]
Caused by: #{maintainTestPlanAssignBean.updateTestPlans}: org.springframework.dao.DataIntegrityViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]; nested exception is org.hibernate.exception.ConstraintViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]
Caused by: org.springframework.dao.DataIntegrityViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]; nested exception is org.hibernate.exception.ConstraintViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]
at de.verit.klaros.web.beans.pages.define.MaintainTestPlanAssignBean.updateTestPlans(MaintainTestPlanAssignBean.java:705)
at de.verit.klaros.web.beans.pages.define.MaintainTestPlanAssignBean_$$_javassist_seam_64.updateTestPlans(MaintainTestPlanAssignBean_$$_javassist_seam_64.java:-1)
Caused by: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]; nested exception is org.hibernate.exception.ConstraintViolationException: could not insert collection: [de.verit.klaros.core.persistent.TestSuite.executables#1c0073b3-6378-4a0a-9404-66f3f1539c0e]
at org.hibernate.persister.collection.AbstractCollectionPersister.recreate(AbstractCollectionPersister.java:1244)
at org.hibernate.action.CollectionRecreateAction.execute(CollectionRecreateAction.java:58)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:267)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:259)
at sun.reflect.GeneratedMethodAccessor844.invoke(null:-1)
at org.hibernate.jdbc.BatchingBatcher.addToBatch(BatchingBatcher.java:56)
at org.hibernate.persister.collection.AbstractCollectionPersister.recreate(AbstractCollectionPersister.java:1207)
Caused by: Duplicate entry 'bc53ad53-4c6a-4ac4-8693-10c9163a0d22-0' for key 'PRIMARY'
Testcase update:
Testsuite update:
RE: paralel save leads to DataIntegrityViolationException
Hi Attila,
thanks for your feedback and reporting this issue.
Are you really sure these stack traces are relating to version 3.4.8? Comparing relevant line information suggests that this is a stack trace from version 3.4.7 or before.
Version 3.4.8 has fixed exactly this problem ([KLAROS-1463] - JDBC batching of versioned data breaks concurrent updates).
the thing is, that we updated Klaros yesterday morning from 3.4.7 to 3.4.8, and there is the possibility, that it occured before the update, i don't know for sure. If it happens again, i'll let you know.
Thanks for the quick reply!
Attila
Attila
