Klaros-Testmanagement 5.7.3 released - Klaros Test Management - Forum - Klaros Test Management
Torsten Stolpmann, modified 9 Months ago.
We are pleased to announce the release of Klaros Test Management 5.7.3.
This maintenance release adds some minor improvements and provides bug fixes for multi-select user defined fields, cross project object synchronization and others.
Overall it provides 4 improvements and 19 bug fixes.
Release Notes Version 5.7.3 (08.05.2025)
Improvements
[KLAROS-5394] - Add the id filter field for the list of report templates
[KLAROS-5395] - Restructure the database installation section in the user manual
[KLAROS-5402] - Add access to system under test and test environment details on the test case execution overview page
[KLAROS-5403] - Pending test runs should be filtered from the resource API for non-admin users
Bug Fixes
[KLAROS-3789] - Creating new user defined properties for already synchronized objects does not trigger creation of these properties when synchronizing and no other changes are present
[KLAROS-5259] - Synchronized test cases and test suites do not display the actual value of their user defined enumeration fields
[KLAROS-5262] - When updating synchronized test cases and test suites, attachments are never added to them
[KLAROS-5390] - Fix filtering after issue id in issue tables
[KLAROS-5393] - Unable to purge a requirement that has been synchronized via the XML synchronization API after being transferred to a different project
[KLAROS-5396] - Attempting to delete a single object list entry may fail with an exception when the same object has been simultaneously purged in another session
[KLAROS-5397] - Error immediately deleting a test run after executing a test case via a related job
[KLAROS-5399] - Missing attributes in the resource rest API
[KLAROS-5400] - Synchronizing test cases with externa test case ids may result in orphan external test case entries
[KLAROS-5404] - Missing field values for test step results in the resource API
[KLAROS-5405] - Category assignments for existing requirements are reset when synchronizing requirements with category assignments from an external source
[KLAROS-5406] - Creating a new item while a category node is selected assigns this item automatically to this category even after the category window is closed
[KLAROS-5407] - After synchronizing newly created user defined properties the details user defined property view of the synchronized objects is not immediately updated with the new entries
[KLAROS-5408] - When updating synchronized objects deleted attachments are never removed
[KLAROS-5409] - When importing test cases via test case result imports the external test case id may temporarily not be visible to the system
[KLAROS-5410] - Managers can assign other users the role of administrator and manager via bulk edit on the user list page.
[KLAROS-5411] - Confusing dialog behavior when an administrator is trying to purge a single object in a list while there are also unsaved new entries present
[KLAROS-5413] - XML export files for projects with user defined multi-selection fields containing a default value can not be imported
[KLAROS-5414] - Creating new multi-select user defined properties does not propagate to create properties for already existing objects
Improvements
Bug Fixes
