RE: Every day when logging in for the first time
I cannot log in and I receive the following error message:
viewId:/send-receive-updates - View /send-receive-updates could not be restored.
Stack trace:
at com.sun.faces.lifecycle.RestoreViewPhase.execute(RestoreViewPhase.java:189)
at com.sun.faces.lifecycle.RestoreViewPhase.doPhase(RestoreViewPhase.java:102)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:-1)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:-1)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:-1)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:-1)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:-1)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:-1)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:-1)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:-1)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:-1)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:-1)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:-1)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:-1)
at java.lang.Thread.run(null:-1)
Next time I log in it works perfectly until the next day.
Should I reinstall the application to fix this?
I fear the real reason for this is dumped to the console or hidden in the log file (logs/catalina.out), as some stack traces get logged without being reported to the UI and the given output is not helpful for analysis. Can you please post the logs here or send them to support@verit.de?
we finally were able reproduce this, it is a bug we are about to analyze.
Thanks for the feedback!
Hi Torsten.
Thank you for the update.
Sorry I have not been able to send the log file to you yet.
Have a great Christmas and thank you for all your help so far!
emoticon
We finally found the cause for this.
This behavior is rooted in http://jira.icefaces.org/browse/ICE-7219 - an incompatibility issue of IceFaces 1.8 starting from tomcat version 6.0.33 and above. See also: https://mail-archives.apache.org/mod_mbox/tomcat-users/201109.mbox/%3C32449101.post@talk.nabble.com%3E
We will roll back the bundled tomcat to version 6.0.32 in the upcoming 3.5 release.
Thanks again for pointing this out.
Cheers,
Great, Torsten, thank you! emoticon
