RE: Trac Issue Management Exception after upgrade
Richard S., modified 14 Years ago.
Youngling Posts: 6 Join Date: 12/10/10 Recent Posts
Hi there!
I just upgraded my klaros-version to 3.4.5 (Communtiy Edition). The issue managment with trac works fine until I made an upgrade.
When I want to verify the Trac-URL in the issue management in klaros I get an exception in the browser window with this trace:
#{maintainIssueManagementBean.checkURL(element)}: java.lang.IllegalArgumentException
       at javax.servlet.http.HttpServlet.service(HttpServlet.java:-1)
       at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:-1)
       at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:-1)
       at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:-1)
       at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:-1)
       at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:-1)
       at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:-1)
       at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:-1)
       at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:-1)
       at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:-1)
       at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:-1)
       at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:-1)
Caused by: #{maintainIssueManagementBean.checkURL(element)}: java.lang.IllegalArgumentException
       at com.icesoft.faces.component.panelseries.UISeries$RowEvent.broadcast(UISeries.java:617)
       at com.icesoft.faces.component.panelseries.UISeries.broadcast(UISeries.java:285)
Caused by: java.lang.IllegalArgumentException
       at org.eclipse.mylyn.commons.net.AuthenticationCredentials.<init>(AuthenticationCredentials.java:38)
       at de.verit.klaros.service.issuemanagement.mylyn.trac.TracIssueManagementService.login(TracIssueManagementService.java:353)
       at de.verit.klaros.service.issuemanagement.mylyn.trac.TracIssueManagementService.checkAuthentication(TracIssueManagementService.java:415)
       at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionImpl.connectService(IssueManagementConnectionImpl.java:67)
       at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionImpl.<init>(IssueManagementConnectionImpl.java:44)
       at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionPoolImpl.createConnection(IssueManagementConnectionPoolImpl.java:40)
       at de.verit.klaros.web.beans.session.MylynAuthenticationBean.getConnection(MylynAuthenticationBean.java:102)
       at de.verit.klaros.web.beans.session.MylynAuthenticationBean_$$_javassist_seam_39.getConnection(MylynAuthenticationBean_$$_javassist_seam_39.java:-1)
       at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean.passwordDialogConnect(MaintainIssueManagementBean.java:129)
       at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean.checkURL(MaintainIssueManagementBean.java:468)
       at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean_$$_javassist_seam_79.checkURL(MaintainIssueManagementBean_$$_javassist_seam_79.java:-1)
       at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:280)
       at org.jboss.el.parser.AstMethodSuffix.getValue(AstMethodSuffix.java:59)
       at org.jboss.el.parser.AstMethodSuffix.invoke(AstMethodSuffix.java:65)
I use ssl in trac and I imported the certificate with the InstallCert-Tool again.
What has changed after I performed this upgrade?
Richard
Hi Richard,
from what version did you upgrade from? 3.4.4?
Rgards,
thank you for the fast answer! I upgraded from 3.3.2
Hi Richard,
I've reproduced this issue and it is a bug.
This is being tracked as KLAROS-1390 (Checking a Trac connection results in an IllegalArgumentException) and should be fixed in the next release.
There is a workaround for the connection validation - if a Trac account exists with the username and password used to log into Klaros-Testmanagement, that will be used to test the connection.
I have not encountered this problem while creating or linking issues, so after setting up the Trac connection you should encounter no further problems.
Hi Richard,
Klaros-Testmanagement 3.4.6 has been released today which should finally resolve this problem.
Please send a notice if you experience any more problems.
