RE: Generate jobs causes NullPointeException - Klaros Test Management - Forum - Klaros Test Management
Klaas Vink, modified 12 Years ago.
Youngling Posts: 3 Join Date: 8/11/11 Recent Posts
Executing test jobs in Plan module, iusing the online demo, I get a NullPointerException and a return to login option.
Not sure what is mssing/went wrong.
During the define mode I have created enough components to do the Plan action.
Project setup = FAS test
Will attach the file with the screen capture and the stack dump.
Hi Klaas,
thanks for reporting the issue!
It appears that generating a job with an assignee selected in the current Klaros version (3.4.4) causes this exception. A workaround for now is to generate the jobs with no assignee selected (the blank entry in the drop-down box) and set the assignee from the maintain jobs page.
We are working to fix this problem (KLAROS-1367 Creating a job on the Generate Jobs from Test Cases/Suites page while an assignee is selected causes a NullPointerException.) and it should be fixed in the next release (3.4.5).
Patrick,
The worrk-around works, but executing the assignment in Maintain jobs, the assignee disappears the moment the save mode is activated.
Is that part of the issue?
Klaas
Klaas
Hi Klaas,
This is a related issue, which will also be fixed in Klaros 3.4.5.
We have updated the online demo to a development snapshot in which these bugs have been fixed.
