Klaros-Testmanagement 5.5.5 released
We are pleased to announce the release of Klaros Test Management 5.5.5.
This release adds new filter options for test cases and test suites according to their category and execution status.
In addition to various smaller improvements and fixes in the issue tracker integration, custom workflows are now supported for Bugzilla.
Overall this release contains 7 improvements and 6 bug fixes.
Release Notes Version 5.5.5 (18.12.2023)
[KLAROS-5195] - Adding assigned test cases in the issue description field should be user selectable
[KLAROS-5216] - Allow to select all not executed test cases on the test case result list page
[KLAROS-5217] - Support category filtering on the test case result selection page
[KLAROS-5218] - Present an icon-only version of the newest result filter select button in the table header
[KLAROS-5221] - Support custom workflows in the bugzilla connector
[KLAROS-5222] - Use icons instead of text in the test result filters on the test case and test suite selection pages
[KLAROS-5227] - Allow to select all not executed test suites on the test suite result list page
[KLAROS-5202] - Error message 'Not Found' is returned when creating a GitHub issue
[KLAROS-5219] - Filtering for newest test case results on the test case details page test case result tab is showing too many entries
[KLAROS-5223] - A saved report template may get reported as still unsaved on the report template list page
[KLAROS-5224] - When creating a new issue after changing to another project the previous issue management system is still preselected
[KLAROS-5225] - Unable to update a bugzilla custom datetime field to a blank value
[KLAROS-5226] - Show the correct start status when creating a new issue
