RE: HTTP Status 404 running overview reports - Klaros Test Management - Forum - Klaros Test Management
Chris Loxley-Watkins, modified 14 Years ago.
Youngling Posts: 3 Join Date: 6/29/11 Recent Posts
I've got the system up and running in MySQL, running Apache as a service and when I try to open any of the overview reports, I get the following: -
HTTP Status 404 - Could not find resource for relative : /reportEnvironmentOverview/P00001/Chris+Loxley-Watkins/7/-1/true/false/html//EnvironmentOverviewReport of full path: http://jazz:18080/klaros-web/seam/resource/rest/reportEnvironmentOverview/P00001/Chris+Loxley-Watkins/7/-1/true/false/html//EnvironmentOverviewReport
I'm using version 3.4.3 - Build 1130 in Internet Explorer 8
Any ideas?
Chris
Any ideas?
Chris
The double / before EnvironmentOverviewReport actually should contain your locale (en or de currently).
To what locale/language is your system configured?
This looks strange.
This looks strange.
OK, it's working but I'm unsure what fixed it
I had both English and German in the list as available languages. I removed German and then tried again but it didn't work. I then clicked on the English (en_US) logo top right corner next to my name and it seems to be working now. Very odd but it's working at least
Thanks for your help
Chris
Chris
I opened bug KLAROS-1333 (HTTP Status 404 running overview reports) to track this, as this definitly should not happen.
I assume you use a en_GB locale on your system?
Yes, this is correct. I've just tried with a new user and it's the same. I click the language icon top right and works fine after that
Chris
Chris
You may try follow the solution in this discussion to enforce a en_US locale for Klaros which should hopefully remedy your problem in the meantime.
