RE: Unable to logon when using MySQL
Chris J Loxley-Watkins, modified 14 Years ago.
Youngling Posts: 3 Join Date: 6/29/11 Recent Posts
I've been trying to get the system working with MySQL and I've managed to set it up and the schema is populated with the Klaros tables but I can't seem to log in. I keep getting
ERROR - 12:46:49 - Authentication failed (wrong user name or password).
I've tried the default of admin, admin but it's still not allowing me to log in. Any ideas?
I am using Windows, running as a service if that makes any difference? I'm also using version 3.4.3 build 1130 which I believe is the latest?
Any help would be appriciated
Chris
Hi Chris,
can you please send the content of your <klaros-installation-dir>/logs directory to support@verit.de so we may have a look?
Thanks Torsten, just sent it over
Chris
RE: Unable to logon when using MySQL (Answer)
As I could not find any error messages in the logs:
Did you make sure that you edited the .klaros/hibernate.properties file in the home of the user account running the service?
I assume the database referenced there has been initialized properly and the K_USER table contains the 4 default accounts, right?
Sorry, I was running the service as a different user account that didn't have access
Many thanks for your help, all working fine now emoticon
Chris
