RE: Import from excel(xls) using curl command is not working.
Bhavesh Soni, modified 2 Years ago.
Youngling Posts: 5 Join Date: 4/27/23 Recent Posts
I have installed the Klaros community edition for evaluation purposes however, excel import using CURL command is not working. Curl Command:
also,I have attached a sample file that I am trying to upload and Project is present. For more details, Please check attached screenshot: Error:
27-Apr-2023 08:33:50.157 INFO [http-nio-18080-exec-7] org.apache.coyote.http11.Http11Processor.service Error parsing HTTP request header  Note: further occurrences of HTTP request parsing errors will be logged at DEBUG level.     java.lang.IllegalArgumentException: Invalid character found in the request target [/klaros-web/seam/resource/rest/import/testcase/xls?config=P00001\&username=admin&password=Password]. The valid characters are defined in RFC 7230 and RFC 3986         at org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:494)         at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:271)         at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)         at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:891)         at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1784)         at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)         at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)         at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)         at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)         at java.base/java.lang.Thread.run(Unknown Source)
Please guide me on how can i import the test cases.
there was an extra '\' in  URL (...config=P00001\&username...).after that I am getting below error
*   Trying 127.0.0.1:18080...
> Host: localhost:18080
> User-Agent: curl/7.81.0
> Accept: */*
> Content-Length: 8704
> Expect: 100-continue
< HTTP/1.1 100
< HTTP/1.1 405
< Content-Language: en
< Content-Length: 685
< Connection: close
* Closing connection 0
<!doctype html><html lang="en"><head><title>HTTP Status 405 – Method Not Allowed</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-coloremoticon525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-coloremoticon525D76;border:none;}</style></head><body><h1>HTTP Status 405 – Method Not Allowed</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Description</b> The method received in the request-line is known by the origin server but not supported by the target resource.</p><hr class="line" /><h3>Apache Tomcat/9.0.71</h3></body></html>
Talal Arif, modified 2 Years ago.
Youngling Posts: 2 Join Date: 1/6/16 Recent Posts
Hello Bhavesh,
Talal
File Location:
*   Trying localhost:18080...
> Accept: */*
< HTTP/1.1 100
< HTTP/1.1 405
< Connection: close
Hello Bhavesh,
-Are you using a proxy?
Talal
Hello Bhavesh,
    1)    Which Klaros version are you using?
    2)    Are you using a proxy?
 My Comments: No
    3)  Are there any error messages in the Klaros log files during the import attempts?
@Torsten:
    1)  can you please also list the content of the webapps folder of your installation?
       My Comments: We did replace following Jar's jxls-reader-2.0.6.jar  and commons-digester3-3.2.jar
Hello Bavesh,
1. When using the docker version, your application URL is indeed http://10.100.26.100:18080/ (without klaros-web in the path, this is only required in the standard installer version).
Hello Torsten,
Thank you for your response.
Thank you so much Talal and Torsten.
Thanks and Regards,
Bhavesh Soni
Hello Bavenosh,
