Redmine - Copy/Paste links to Klaros Test cases inside a redmine issue - Klaros Test Management - Forum - Klaros Test Management
Stephane Moser, modified 14 Years ago.
Youngling Posts: 6 Join Date: 5/25/11 Recent Posts
I've searched without any success where I could find the link to a test case. When we run a test suite / test case, we can create new issues inside Redmine. If we do so, there is a link automatically inserted inside the issue have as a target the test case result.
There is one :
http://localhost:18080/klaros-web/browse.jsp?type=testCaseResult&uuid=962e6bbc-7118-49d7-9255-e1e8294cec53
When we click on the link, we are redirected to the test case result. It's fine.
Is there a way to know the link to a test case ? To be able to copy/paste links to klaors test cases inside a redmine issue ?
This way we could link klaros to redmine and redmine to klaros...
Thanks in advance
Stéphane
There is one :
Thanks in advance
Stéphane
RE: Redmine - Copy/Paste links to Klaros Test cases inside a redmine issue
Hi Stéphane,
You can find this link as shown below. Please note that following the link will lead to a redirection, so the resulting link shown in the browser will not be usable.
The same applies to the print-icon links in the define section which can also be referenced from outside Klaros.
RE: Redmine - Copy/Paste links to Klaros Test cases inside a redmine issue (Answer)
Ok fine, I've found how to have the link I expected. I was asking for test case link, not test case result link. But it's ok... When you click on 'edit' the test case, your browser url changes to a specific url with an id related to the test case.
Thank you for your help.
Best regards
Stéphane
Best regards
Stéphane
