RE: own created report crashed after Release Update - Klaros Test Management - Forum - Klaros Test Management
Jenni Wilms, modified 2 Years ago.
Youngling Posts: 6 Join Date: 7/11/19 Recent Posts
Dear Support,
I created own report. After your Release Update in the cloud (June 2022), my version (version number is correct) is still there, but the content is an very old one (all my modifications within Script and Layout are missing).
What happened?
Thank you for your support and best regards,
Jenni
What happened?
Jenni
Hello Jenni,
we were able to reproduce the problem and are looking for a solution.
Can you confirm that this only applies to rendering the reports and that the script and template sources are up to date in the editor?
Dear Torsten,
the Script and Layout content in the editor are not up to date in the editor.
I also not able to update the content, the changes are not saved.
When I make a copy of the report, I am able to change the Script and Layout in the editor, but not in the original one.
Jenni
Jenni
Dear Jenni,
this issue should now be resolved with the release of version 5.4.1 and the report should now be accessible as expected.
Thanks again for reporting!
