RE: Reset admin account
Epsilon AB IT, modified 14 Years ago.
Reset admin account
Youngling Posts: 2 Join Date: 2/10/11 Recent Posts
Due to a weird reason, our only admin account has the same User name as one of the test managers, and when trying to log in one the the error message:
"#{userHandler.login}: /pages/include/includeLogin.jspx @47,80 action="#{userHandler.login}": org.springframework.dao.IncorrectResultSizeDataAccessException: query did not return a unique result: 2 "
We tried to uninstall and reinstall Klaros to reset the accounts, but no success.
Changed name of the "Klaros-Testmanagement"-folder and installed again, but no success.
My question is: How do we reset the user accounts so we have an admin account again?
Cheers!
Hello anonymous user from Epsilon AB IT,
User names are stored in the database (which one have you configured?) in the K_USER table.
If you have not yet configured a database you are using an Apache Derby instance with the data directory in <user_home>/.klaros/klarosDerby.
Database settings are store in <user_home>/.klaros/hibernate.properties so using a (JDBC based) SQL Database Editor you should be able to correct your entries.
I am unsure on how you were able to achieve that situation (it should not be possible), so any more information like logfiles or a description of what was entered is very welcome.
I had a user (epsilon) that was an system account. He didnt have any rights to log in so I logged in as admin/admin ->configure -> search users -> edit on felix musterman -> changed name etc to the same as (epsilon)
tada, now you couldnt log in anymore.
thank you for your hint. I'm able to reproduce this behavior and created an issue to fix this. (KLAROS-1201: It is possible to change the username to an already existing value what causes an exception at the log in screen). We will provide a fix in our next release.
RE: Reset admin account (Answer)
Fixed with the release of version 3.3.
