Using Klaros with Apache reverse proxy - Klaros Test Management - Forum - Klaros Test Management
Maciej Sawicki, modified 13 Years ago.
Youngling Posts: 5 Join Date: 1/27/11 Recent Posts
I installed Klaros on our development server. I would like to make url little nicer. I setuped reverse proxy:
It almost works, but there is issue with test execution. The pop up window is displaying login dialog instead of actual test case and it doesn't allow to login, so i can't continue executing.
I will appreciate any advice.
regards,
Maciej Sawicki
# mod_proxy setup. | |
ProxyRequests Off | |
ProxyPass /klaros-web http://127.0.0.1:18080/klaros-web | |
ProxyPassReverse /klaros-web http://127.0.0.1:18080/klaros-web | |
<Location "/klaros-web"> | |
# Configurations specific to this location. Add what you need. | |
# For instance, you can add mod_proxy_html directives to fix | |
# links in the HTML code. See link at end of this page about using | |
# mod_proxy_html. | |
# Allow access to this proxied URL location for everyone. | |
Order allow,deny | |
Allow from all | |
</Location> |
regards,
Maciej Sawicki
Tobias Schmitt, modified 13 Years ago.
RE: Using Klaros with Apache reverse proxy (Answer)
Hi Maciej,
can you please check the parameter "Application URL" in the category "Configure" in Klaros-Testmanagement. You can find it under "System Parameters | General". This parameter must be set to the new proxy URL of Klaros. Without this, Klaros will not work properly when running behind a proxy.
Hi Tobias,
Thank You for quick answer. the url wasn't set. After setting it to https://somedomain/klaros-web everything works grate.
