Evaluate screen issues. - Klaros Test Management - Forum - Klaros Test Management
Hi there.
Again perhaps something I did on upgrading but not sure.
I jhave been trying to figure out why I cannot see my graphs on the Evalute page. seems even on project I know had graphs before now show the signs sayin no test environment has been tested. yet if I look at a test case results level. I can see that i have results showing tests passed etc.
Does the Evaluate dashboard only show graphs for test runs and not executions of test cases?
I tried checking on the icons next to the pains to see what options were available in the dash board but cannot see anything that helps.
Incidently I cant get the overview reports to work either
RE: Evaluate screen issues.
Hi Jamie,
What is the exact message? You have to have results available for the combination of SUT and test environment to be shown.
No.
There is a slight chance you might suffer from previous incompatible settings saved. Have you tried changing the values and saving them?
I cannot reproduce any of the errors you mentioned above. Is the log output showing anything suspicious?
No.
Hi Torsten. Will send you a pM with screen shots
RE: Evaluate screen issues. (Answer)
Hi there. You can mark this one as resolved.
Torsten. thanks for the Link it did the trick.
Have a good weekend!
