RE: Testrun crashes after update to 3.2.1 - Klaros Test Management - Forum - Klaros Test Management
Vlad M, modified 15 Years ago.
Youngling Posts: 2 Join Date: 11/23/10 Recent Posts
in version xy (sorry, i dont know right now..)
i created some testsuites, consisting of some testcases.
everything went fine, i was able to finish every testsuite run.
we updated klaros to version 3.2.1( - Build 771) and now every testsuite, created before the update,
crashes after 3 or 4 steps. (see error message below)
a new testsuite with new testcases, created in the current version 3.2.1, runs fine
Problem in renderResponse: javax.el.ELException: /pages/subviews/execute/runner/subviewTestPlanSteps.jspx @132,51 value="#{testPlanRunner.currentStepObject.preCondition}": Error reading 'currentStepObject' on type de.verit.klaros.web.beans.pages.runner.TestPlanRunner_$$_javassist_seam_85 |
Hi Vlad,
to analyze the problem we need at least a full stack trace (if you are running under linux the file log/catalina.out, for windows we need the console output) of the incident and the version number you updated from. Please send this to support@verit.de.
Thanks for your feedback!
Vlad,
we were able to reproduce this and tracked this issue as KLAROS-1083 (Wrong index for current test case when executing test suites). This is a regression introduced in version 3.2.0 and has been fixed towards version 3.2.2 which will be available tomorrow.
Thanks for pointing that out!
we just updated our Klaros to version 3.2.2 and now my testsuites run fine!
thanks a lot for your fast response!
