RE: Klaros-Testmanagement version 3.1 released
Klaros-Testmanagement version 3.1.2 released
As the most prominent feature Klaros-Testmanagement 3.1 now supports the popular Mantis Issue Tracker.
In addition, the following features have been added:
  • Test runs and individual test results now have a permanently valid URL, so that they can be linked to from other applications
  • Access to these URLs can be limited to authenticated users only
  • The quick search allows the direct navigation to individual detail pages by entering the ID of the object to look for
  • New issues will contain links to the referenced test results, and existing issues can be assigned to test cases at any time
  • The import of test result files is available directly from the GUI now and has been extended from QF-Test and JUnit files to AUnit, Boost Test, CppTest, CppUnit, Free Pascal Unit, MSTest, NUnit, PHPUnit, UnitTest++ and Tusar formats as well
  • The test runner now contains its own status log
  • The test environment is now automatically prefilled in JIRA issues
Release Notes:
Version 3.1.2 - 2010-10-28:
Version 3.1.1 - 2001-10-01:
Version 3.1.0 - 2010-09-01:
New Features:
Version 3.0.4 - 2010-08-13:
Version 3.0.3 - 2010-08-06:
New Features:
Version 3.0.2 - 2010-07-26:
Version 3.0.1 - 2010-07-19:
New Features:
Version 3.0.0 - 2010-07-16:
New Features:
[KLAROS-750] - white box in Tabs when selecting "Testf lle verwalten"
Robert Munteanu, modified 15 Years ago.
Youngling Posts: 5 Join Date: 9/2/10 Recent Posts
Torsten Stolpmann:
Congratulations on the new integration. Out of curiousity, how are you interacting with Mantis ( SOAP/DB access/ Import-Export ) ?
Hi Robert,
we are using the Mantis Connect SOAP interface.
