RE: font too small in HTML report
* create an HTML report for Test Environment, SUT or Test Suites
-> the font is way too small; you always need to zoom in which blurs bitmaps way beyong their resolution
note: font size is fine in PDF reports
another thing that I noticed is that a often get an error "no data to create report" the first time I try to trigger a report. it works the second time I click. will watch this.
HTML output is still page-oriented, so the font size is chosen relative to the page dimensions. Nonetheless I agree about the ugliness here. PDF and HTML output are rendered from the same reporting template, so we are pretty much tied to the behavior of the reporting framework used here. We will see what is posible here (tracked as KLAROS-956 - Predefined HTML Reports lack readability).
Please provide a log file if possible.
thanks for checking into this!
does this help? do we need to set autoreconnect=true in the MySQL connection string? Jira is using both - autoreconnect as well as a validationQuery="select 1" parameter.
11:35:28,793 ERROR TestSuiteOverviewReportServlet:145 - Unable to build report
de.verit.klaros.core.exception.KlarosReportException: Can not fill the report [r
eports/KlarosEnvironmentReport.jrxml]
Caused by: net.sf.jasperreports.engine.JRException: org.hibernate.TransactionExc
eption: JDBC begin failed:
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last pac
ket successfully received from the server was 82.526.013 milliseconds ago. The
last packet sent successfully to the server was 82.526.013 milliseconds ago. is
longer than the server configured value of 'wait_timeout'. You should consider e
ither expiring and/or testing connection validity before use in your application
, increasing the server configured values for client timeouts, or using the Conn
ector/J connection property 'autoReconnect=true' to avoid this problem.
Hi Markus,
we already had another user with the same timeout problem. You can use the solution from this forum entry by Michaël Erni.
thanks, Tobias.
just added the autoconnect parameter for now. maybe when you get the time you can check if hibernate allows to send a validation query ("select 1") in regular intervals to keep the connection alive the way Jira does it. could even be part of the JDBC driver.
gruss,
Markus
