RE: Created By is empty for Jira bugs - Klaros Test Management - Forum - Klaros Test Management
Markus Krieg, modified 11 Years ago.
after createding bugs in Jira, I checked the Issues By Test Case screen.
I can see all fields fine and also the reflected priority and status live from Jira (cool!). however, the Created By field is empty although there are correct Reporter entries in the bugs in Jira - this is the login name from Jira not the login name from Klaros.
Hi Markus,
I tested it on my local installation and you are right, something is wrong with the Jira owner field. I created the bug KLAROS-947 (The field "owner" contains the wrong value for JIRA issues) to track this issue.
Markus: are you using a different JIRA account name than the one you are logged in via Klaros?
Torsten, I tested it both ways, with the same and different account names, both crateing and viewing issues. it wa broken in all cases.
