RE: Transferring Test cases between projects
Jamie Gagnon, modified 11 Years ago.
Youngling Post: 1 Join Date: 8/20/10 Recent Posts
It would be good if you could transfer test cases between projects. Sometimes you might well have a test case or 2 that can be used again in another project. It would certainly avoid the need for a complete re-write
Hi Jamie,
this is indeed a useful feature. We see this as a copy operation which will only include the test case data itself, loosing the result relations, attachments etc.
I tracked this as issue KLAROS-942 (Provide the ability to copy selected test cases to another project), targeted at the 3.2 release.
Thanks for your input!
