RE: 250 char limit while editing test case step - Klaros Test Management - Forum - Klaros Test Management
Martin Schroeder, modified 11 Years ago.
Youngling Posts: 2 Join Date: 5/10/10 Recent Posts
If i try to save a testcase with a step that has a textbox with more than 250 char i get the following error.
Although i would say 250char is too limited, it would be ok if the application would handle it in a proper way.
e.g. giving a message that it is too long with having the possibility to go back.
Best regards
Martin
Problem in renderResponse: /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}" /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}": Error reading 'viewId' on type de.verit.klaros.web.beans.navigation.NavigationLoginBean_$$_javassist_seam_11
at com.icesoft.faces.application.D2DViewHandler.renderView(D2DViewHandler.java:159)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
Caused by: Problem in renderResponse: /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}" /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}": Error reading 'viewId' on type de.verit.klaros.web.beans.navigation.NavigationLoginBean_$$_javassist_seam_11
at com.sun.facelets.tag.TagAttribute.getObject(TagAttribute.java:235)
at com.sun.facelets.tag.TagAttribute.getValue(TagAttribute.java:200)
at com.sun.facelets.tag.ui.IncludeHandler.apply(IncludeHandler.java:57)
at com.sun.facelets.tag.CompositeFaceletHandler.apply(CompositeFaceletHandler.java:47)
at com.sun.facelets.tag.jsf.ComponentHandler.applyNextHandler(ComponentHandler.java:314)
at com.sun.facelets.tag.jsf.ComponentHandler.apply(ComponentHandler.java:169)
at com.sun.facelets.tag.jsf.core.ViewHandler.apply(ViewHandler.java:109)
at com.sun.facelets.compiler.NamespaceHandler.apply(NamespaceHandler.java:49)
at com.sun.facelets.compiler.EncodingHandler.apply(EncodingHandler.java:25)
at com.sun.facelets.impl.DefaultFacelet.apply(DefaultFacelet.java:95)
at com.icesoft.faces.facelets.D2DFaceletViewHandler.renderResponse(D2DFaceletViewHandler.java:274)
Caused by: /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}" /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}": Error reading 'viewId' on type de.verit.klaros.web.beans.navigation.NavigationLoginBean_$$_javassist_seam_11
at com.sun.facelets.tag.TagAttribute.getObject(TagAttribute.java:233)
Caused by: /pages/login.jspx @29,57 src="#{navigationLoginBean.viewId}": Error reading 'viewId' on type de.verit.klaros.web.beans.navigation.NavigationLoginBean_$$_javassist_seam_11
at org.jboss.seam.core.SynchronizationInterceptor.aroundInvoke(SynchronizationInterceptor.java:41)
at de.verit.klaros.web.beans.navigation.NavigationLoginBean_$$_javassist_seam_11.getViewId(NavigationLoginBean_$$_javassist_seam_11.java:-1)
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:54)
Best regards
Martin
Hi Martin,
Thank for your report. We are currently working on our next major release and this is one of our open tasks. We will expand the maximum size for the test case steps and will improve our exception handling so you still can work.
Hi Martin,
with the release of version 3.0 test case step items (precondition, postcondition, description) are now limited to 1000 characters and the UI enforces these limits.
thanks for reporting!
