RE: Hudson - Klaros Test Management - Forum - Klaros Test Management
RE: Hudson
Hi!
I've just finish to install the new version of Klaros Testmanagement.
Everything work well execpt one thing: Hudson import.
Does somthing change?
I use exactly same configuration and get an error 400.
Hudson Message:
xport of TEST-file-868110337.xml failed - Response status code: 400 for request URL: http://172.20.0.201/seam/resource/rest/importer?config=P00001&env=ENV00001&sut=SUT00001&type=junit&username=hudson&password=XXXXXXX
Catalina.out:
09:18:15,445 ERROR ImportResultServlet:253 - empty String
By the way, still have time problem. It's 11:20am and the Klaros manager use 09:12 am.
any ideas?
Best.
Mike
Hudson Message:
Catalina.out:
any ideas?
Best.
Mike
RE: Hudson
Hi Mike,
Can you please send this result file (TEST-file-868110337.xml) to support@verit.de for analysis?
Have you checked the timezone settings on your server machine? What does
output when started in a shell?
Hudson Message:
any ideas?
any ideas?
date |
RE: Hudson
Hi Mike,
Thanks for sending the result file. The error is caused by a missing time attribute in the testsuite tag, possibly because cppunit does handle this differently than JUnit.
We tracked this behavior as KLAROS-907 (Missing suite execution time attribute causes cppunit based junit import to fail) and have a fix available (we actually never needed reading that attribute) which will be released with the upcoming 3.0.2 Hotfix release.
Thanks for reporting!
Hudson Message:
Catalina.out:
Catalina.out:
RE: Hudson
Hi Mike,
the just released version 3.0.2 has a fix available for this problem.
Hi!
Now the test cases are correctly imported
But I peraps found an other "bug".
When I run Hudson, the importation of the xml file only show me number of test result = failed.
I've no informations about succes and error.
Any ideas?
Best,
Mike
P.S: Correct result are:
- 58 Succes
- 3 Failed
- 0 Error
Edit: By the way. After Test cases importation from Hudson, I still have the "Refresh problem". But only on one way. If I switch from the Manual Project to the Automated one it's okay. If i switch from the Automarded Project to the manual one I Have test cases of both project.
Any ideas?
Best,
Mike
- 58 Succes
- 3 Failed
- 0 Error
RE: Hudson
Hi Mike,
This is a bug, I opened KLAROS-911 (Imported, passed test results are not correctly identified) scheduled for version 3.0.3.
We need to investigate on this. Since we don't have your setup - can you please give some more detail on which pages/objects are affected?
