Klaros-Testmanagement 5.2.0 released - Klaros Test Management - Forum - Klaros Test Management
We are happy to announce the availability of Klaros-Testmanagement 5.2.0. This is a major release that includes a total of 21 new features, improvements and bug fixes.
New features include:
New verdict 'inconclusive'
In addition to the existing verdicts (passed, failed, error, skipped), a new verdict 'inconclusive' has been introduced, which should be used if a test result cannot be clearly identified as passed or failed.
Permanent removal of report templates
A new purge function allows to permanently remove deleted report templates from the data storage.
Easier upload of attachments
Uploading attachments is easier than ever. Only three clicks are necessary to upload an attachment file to Klaros-Testmanagement.
Additionally, Chrome based browsers accept uploading of attachments directly from the clipboard using Ctrl-V.
Faster dashboard reports
The reports on the dashboard significantly load faster, especially for large numbers of results.
Categorization of test segments
Test Segments can now be organized in multiple categories, just like test cases, test suites and other objects in Klaros-Testmanagement.
Release Notes Version 5.2.0 (01.09.2021)
New features
[KLAROS-4870] - Add an option to (bulk) purge report templates
[KLAROS-4869] - Support direct upload of attachments without an additional upload dialog
[KLAROS-4839] - Introduce a new result verdict 'Inconclusive'
[KLAROS-1444] - Support pasting clipboard content to attachments directly for Chrome based browsers
Improvements
[KLAROS-4860] - Faster rendering of dashboard reports
[KLAROS-4850] - Validate custom report parameters on the reports list page
[KLAROS-4847] - Add a 'Test Suite Results' tab to the test run detail page
[KLAROS-4845] - Add a 'Test Runs' tab to the test case and test suite detail pages
[KLAROS-4838] - Allow test segments to be organized in categories
[KLAROS-4796] - Improve loading speed for results and test runs
[KLAROS-4683] - Optionally transfer user defined property definitions and values when copying objects between projects
Fixed Bugs
[KLAROS-4857] - Unable to properly finish a test case execution after the finish test case confirmation dialog has been cancelled
[KLAROS-4854] - Sub jobs may potentially appear in the wrong order on the parent job page
[KLAROS-4846] - If a project with an iteration is active, results on other project detail pages are hidden
[KLAROS-4843] - Impossible to generate the Job Status Report if 'Show Closed Jobs' is unselected
[KLAROS-4842] - Impossible to generate the predefined test run history report
[KLAROS-4841] - Unable to purge test run due to foreign key violation for time blocks
[KLAROS-4837] - Moving a custom report parameter to a new position using the button in the action column does not work
[KLAROS-4836] - Saving changes to a report template shows multiple saving confirmation messages
[KLAROS-4835] - Potentially wrong calculation of skipped test case results in the test run overview
[KLAROS-4832] - Exception when trying to change the default value of a user defined enum field
New features
Improvements
Fixed Bugs
