Hanaa Saroar, modified 11 Years ago.
Youngling Posts: 2 Join Date: 8/9/10 Recent Posts
Jedi Council Member Posts: 768 Join Date: 2/12/09 Recent Posts
Hi Hanaa,
Use XML:
Use a common excel format:
What do you think?
Deepak Vishwakarma, modified 14 Years ago.
Youngling Post: 1 Join Date: 11/16/10 Recent Posts
Hello Tarsten,
Hello Deepak,
Hope this helps, regards
Mike Thirdy, modified 12 Years ago.
Youngling Post: 1 Join Date: 1/9/13 Recent Posts
Torsten Stolpmann:
Thanks in advance,
Mike
Hello Mike,
Sure, here you go.
Tobias Wagner, modified 4 Years ago.
Youngling Post: 1 Join Date: 2/25/21 Recent Posts
Hey community,
Thanks and best regards
Tobias Wagner
Hello Tobias,
thank you for your feedback!
There are  alternatives available, but the existing code is not suitable for an export scenario.
