LDAP configuration (Users are memberOf a CN) - Klaros Test Management - Forum - Klaros Test Management
Matthias Koch, modified 4 Years ago.
Youngling Posts: 4 Join Date: 11/30/20 Recent Posts
we're currently try to integrate Klaros into our active directory. We are able to get users from a OU. Unfortunatley we don't have a own OU where all the users of Klaros are organised. To identify a User which is allowed to access Klaros we have to check if a user is MemberOf a specific CN. Is there any way to setup a filter in the LDAP integration?
As an alternative way we could use the CN of the group as "
Kind Regards,
Matthias
User Context DN" but then we have to search for the "Member"-Atribute instead of a objectClass.
Kind Regards,
Matthias
RE: LDAP configuration (Users are memberOf a CN)
Hello Matthias,
if you like to prevent other users in your active directory to log in to Klaros, please set the option Disable automatic user registration and create the user accounts you require in the Klaros user administration. This way only existing users can authenticate themselves via LDAP/AD.
LDAP Group membership filters are currently not implemented, yet a feature request already exists for that (KLAROS-2991).
I added your request for this feature to this ticket.
P.S.: As an Enterprise Edition user you may also contact us directly under support@verit.de. We are always happy to help.
Hello Torsten,
Thank you very much for your fast reply.
We were just playing arround with the option you mentioned and it solved our issue. Good to know, that you have the membership filters already on your feature list. I think this feature could help in selecting the right group of users in many companies.
Thanks for the direct mail address. In this case I thougt it could be also an interessting topic for other users, that's why I have choosen the forum to ask instead of sending a direct mail. I hope that's ok.
Kind Regards,
Matthias
Kind Regards,
Matthias
Hi Matthias,
It's totally ok, I just wanted to point out your options.
Glad that this solved your issue.
