RE: 404 error when default Database changed to MariaDB - Klaros Test Management - Forum - Klaros Test Management
Ijaz Alam, modified 4 Years ago.
Youngling Posts: 6 Join Date: 11/11/20 Recent Posts
I hope you are doing great.
IAs Klaros recomendes to change the default
So after changing the DB from Apache to Database to Maria DB by doing changes in hibernate.properties file in /.kalros folder in home directory, new Database in MariaDB is created successfully and all the tables are also created.
but when I accessed the application it throws 404 error.
Files attached are:
Logs file from home directory, DB table snapshot which are created, and 404 error when accessing the application.
Please guide how to fix this issue. I have done everything described in Manual given.
Apache Derby Database
(as descrubed in manual as well :https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.changeDB.html).So after changing the DB from Apache to Database to Maria DB by doing changes in hibernate.properties file in /.kalros folder in home directory, new Database in MariaDB is created successfully and all the tables are also created.
Files attached are:
Hi Ijaz,
thanks for the detailed report, especially for the logfile, which contains the following error message:
org.hibernate.boot.registry.selector.spi.StrategySelectionException: Unable to resolve name [org.hibernate.dialect.MariaDB13Dialect] as strategy [org.hibernate.dialect.Dialect]
It seems that you have a small typo in your hibernate.properties file.
Please replace the line
hibernate.dialect = org.hibernate.dialect.MariaDB13Dialect
with the following line:
hibernate.dialect = org.hibernate.dialect.MariaDB103Dialect
Then you should be able to access the web interface of Klaros-Testmanagement.
The dialect is only checked after the inital table creation phase, this is why you can see all tables in your database tool.
Thanks for your reply,
I have corrected the typo changes as you said but issue is still the same.
On web interface message is still same "The requested resource [/klaros-web/pages/login.seam] is not available"
I am attaching new log for the refernce.
RE: 404 error when default Database changed to MariaDB (Answer)
Hi Ijaz,
it looks like the default users have not been created in the k_user table. This is usually done automatically during startup, but it seems to have been skipped due to the false dialect error.
Since it is a fresh database, you can simply try to delete and recreate the database and then start Klaros-Testmanagement again. This will recreate all database tables and should create the default users.
