RE: Access Klaros from other computer in netwrok - Klaros Test Management - Forum - Klaros Test Management
Roland E Nallbani, modified 5 Years ago.
Access Klaros from other computer in network
Youngling Posts: 3 Join Date: 10/1/20 Recent Posts
Hello
Hi Roland,
Youngling Posts: 3 Join Date: 10/1/20 Recent PostsFabian KlaffkeHi Roland,
Hi Roland,
Hope this helps
Hope this helps
Hey
Thanks it works now,
RE: Access Klaros from other computer in network (Answer)
Hi Roland,
