RE: Unable to change the Test Environment and the System Under Test option
Miguel Calvimonte, modified 5 Years ago.
Youngling Post: 1 Join Date: 5/8/20 Recent Posts
When attempting to create or modifying the Latest Success Rate or the Latest Activity reports on the dashboard, is not possible to change the values of the Test Environment and the System Under Test lists in the options. Is this a bug or a limitation of the Community Edition of Klaros?
Miguel
RE: Unable to change the Test Environment and the System Under Test option (Answer)
Hi Miguel,
this is a limitation of the community edition. The enterprise edition lets you choose these parameters as well as the project/iteration of the dashboard report.
Hope this helps.
