RE: Integrating with JIRA from Klaros Community Edition - Klaros Test Management - Forum - Klaros Test Management
SHAHUL YUSOOF, modified 5 Years ago.
Youngling Posts: 4 Join Date: 1/26/20 Recent Posts
Hello ,
When I tried test that Token using Postman , it is able to connect and authenticate. Below is the error in the log that we got :
Appreciate any help ..
RE: Integrating with JIRA from Klaros Community Edition (Answer)
Hello Shalul,
I am setting up for JIRA by choosing the system as Jira .. I am not actually selecting the Jira Legacy option . By selecting the System as Jira, I am giving the User ID as my mail User id and the API Token as the password . Attached the screen shot for reference. It says sometimes the PROJECT does not exist or sometimes the Null pointer excetion . It is not actually authenticating and getting integrated. Please find attached the screen shot for the reference.
Shahul
Shahul
Hello Shahul,
Thank you for reporting!
Ibraim Asanov, modified 5 Years ago.
Youngling Posts: 6 Join Date: 1/30/20 Recent Posts
Hi all,
Ibraim
Ibraim
Hi Shahul and Ibraim,
Only thing is that After I linked the Test cases to the Defect , When I click the Issue, it not directly going to the page.. It is asking my User ID . Please find attached the screen shot. Please advise .
Appreciate your help ..
Hi Shahul,
Clicking on the issue id (NHB-2) will link you to your external Jira system, where you need to login with your Jira credentials. To view and edit an issue in Klaros, please press the edit button instead (I've marked it on the attached screenshot).
Hi Ibraim,
See also: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.html#User-Manual.Installation.IssueManagement.jira
Hi Fabian,
Ibro
Ibro
Hi Ibraim,
- the logs folder in the installation directory
- the logs folder within the .klaros directory
Hi Fabian,
Regards!
Regards!
Hi Ibrahim,
05-Feb-2020 13:12:02.008 INFO org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jdk-9.0.1
05-Feb-2020 13:12:02.008 INFO org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 9.0.1+11
Ibraim
Ibraim
Hi Ibraim,
This all looks good to me, Linux is the better choice anyway
Ibraim
Ibraim
Hi Ibrahim,
