Install Klaros on ubuntu - Klaros Test Management - Forum - Klaros Test Management
Aleksandr Plistik, modified 6 Years ago.
Youngling Post: 1 Join Date: 7/26/19 Recent Posts
Hi all,
I have a problem with start Klaros on Ubuntu.
After succesful instalation, I get an error
In cataslina.out
What am I wrong with?
Thanks and regards
ERROR, org.hibernate.proxy.pojo.javassist.JavassistLazyInitializer HHH000142: Javassist Enhancement failed: de.verit.klaros.core.persistent.CategoryReference | |
java.lang.NullPointerException: null |
Thanks and regards
RE: Install Klaros on ubuntu (Answer)
Hi Aleksandr,
the log indicates that you are using a Java 11 Runtime which is currently unsupported. You will require Java 8 for this to work.
Please refer to the following resources for details:
Installation Requirements: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.html#User-Manual.Installation.Prerequisites.Server
JDK-related blog entry: https://www.klaros-testmanagement.com/blog/-/blogs/roadmap-migrating-from-oracle-java-runtime-environment-to-openjdk
