RE: Creating Jobs From JIRA Tickets - Klaros Test Management - Forum - Klaros Test Management
Erinc Cagri Ozcicek, modified 6 Years ago.
Youngling Posts: 4 Join Date: 4/1/19 Recent PostsHi,
Thank You,
Best Regards
Cagri
Hi Erinc,
(Note: the Jira filter API is currently not supported here, but it is in our backlog as KLAROS-3135. But you can already limit the issue types that should be synchronized)
Hi Fabian,
Thank you for your support.
Hi Erinc,
Best Regards,
Cagri
Best Regards,
Cagri
RE: Creating Jobs From JIRA Tickets (Answer)
Hi Erinc,
you're welcome! Please let us know if it worked after upgrading Jira and/or if you need additional help.
Hi Erinc,
We have JIRA filters containing tickets regarding to changed software product parts. With these tickets we want create test exexcution jobs that contains the regression tests that are related with changed software parts.
Best Regards,
Best Regards,
