Redmine Authentication Failed - Klaros Test Management - Forum - Klaros Test Management
Bev Dellosa, modified 7 Years ago.
Youngling Posts: 7 Join Date: 12/21/18 Recent Posts
Redmine version: 3.4.1 stable
Klaros version: 4.9.7
Mylyn version: 2.8.2 stable
Thank You,
Bev
Thank You,
Bev
Hi Bev,
2018-12-20 00:42:39: ERROR, de.verit.klaros.web.handler.GlobalExternalConnectionHandler, http-nio-18080-exec-1 Unable to connect to external server IM00001 at http://192.168.168.222/login | |
de.verit.klaros.exception.KlarosServiceException: net.sf.redmine_mylyn.core.RedmineStatusException: net.sf.redmine_mylyn.api.exception.RedmineApiHttpStatusException: Unexpected status code - 404 Not Found |
Bev
Bev
Hi Bev,
Thank You,
Bev
Thank You,
Bev
Hi Bev,
There is no proxy server involved here. I also tried adding a trailing slash but still got the same issue.
Bev
Bev
RE: Redmine Authentication Failed (Answer)
Hi Bev,
Hi Fabian,
Bev
Bev
Hi Bev,
the screenshot you've provided shows the settings screen, but the project names are instead listed on the projects page (Administration/Projects):
Hi Fabian,
You're right, I was looking at the wrong screen.Â
I changed the Project ID and it is working now!Â
Thanks so much to you and to Torsten for being patient with me.
Best Regards,
Bev
Best Regards,
Bev
Hi Bev,
Be sure to check out this page if you run into any other issues, though!
