Update from DB 4.9 to 4.12 fails
Dominic Gerber, modified 7 Years ago.
Youngling Posts: 2 Join Date: 4/6/18 Recent Posts
I'm trying to update my TestManagement installation version 4.2.4. Unfortunately I cannot go directly to the newest version 4.8.4. So I try updating every major version. But the update process fails already at 4.3.1.
Deploying and starting up the website worked. Although there where shown two errors at the console:
2018-04-06 10:18:32: ERROR, org.hibernate.tool.hbm2ddl.SchemaUpdate HHH000388: Unsuccessful: create index IDX_K_TEST_CASE_10 on K
2018-04-06 10:18:32: ERROR, org.hibernate.tool.hbm2ddl.SchemaUpdate Index 'IDX_K_TEST_CASE_10' already exists in Schema 'ROOT'.
When opening the startpage http://localhost:18080/klaros-web/pages/login.seam it tells me the following:
Active Database Revision:
4.9
Current Database Revision:
4.12
After loging in with my admin account, the DB got updatet without any errors. After this process the login screen is shown again. After trying to login the next time, the login does not work. Instead I get the following exceptions in the console:
2018-04-06 10:35:25: ERROR, de.verit.klaros.web.handler.UserHandler
org.jboss.seam.InstantiationException: Could not instantiate Seam component: defineProjectsBean
        at org.jboss.seam.Component.newInstance(Component.java:2208) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.getInstance(Component.java:2034) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.getInstance(Component.java:1996) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.getInstance(Component.java:1990) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at de.verit.klaros.web.handler.UserHandler.doRedirectOrInitProjectBean(UserHandler.java:248) ~[UserHandler.class:na]
        at de.verit.klaros.web.handler.UserHandler.login(UserHandler.java:190) ~[UserHandler.class:na]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_151]
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_151]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_151]
        at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_151]
        at org.jboss.seam.util.Reflections.invoke(Reflections.java:22) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:79) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at de.verit.klaros.web.beans.interceptor.ConfigurableSynchronizationInterceptor.aroundInvoke(ConfigurableSynchronizationInterceptor.java:45) [ConfigurableSynchronizationInterceptor.class:na]
        at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:196) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:114) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at de.verit.klaros.web.handler.UserHandler_$$_javassist_seam_33.login(UserHandler_$$_javassist_seam_33.java) [UserHandler.class:na]
        at de.odysseus.el.tree.impl.ast.AstProperty.invoke(AstProperty.java:205) [juel-impl-2.2.7.jar:2.2.7]
        at de.odysseus.el.tree.impl.ast.AstEval.invoke(AstEval.java:71) [juel-impl-2.2.7.jar:2.2.7]
        at de.odysseus.el.TreeMethodExpression.invoke(TreeMethodExpression.java:132) [juel-impl-2.2.7.jar:2.2.7]
        at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105) [jsf-impl-2.1.29-03.jar:2.1.29-03]
        at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:87) [jsf-api-2.1.29-03.jar:2.1]
        at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:101) [jsf-impl-2.1.29-03.jar:2.1.29-03]
        at net.bull.javamelody.JsfActionListener.processAction(JsfActionListener.java:64) [javamelody-core-1.56.0.jar:1.56.0]
        at javax.faces.component.UICommand.broadcast(UICommand.java:315) [jsf-api-2.1.29-03.jar:2.1]
        at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:786) [jsf-api-2.1.29-03.jar:2.1]
        at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1251) [jsf-api-2.1.29-03.jar:2.1]
        at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81) [jsf-impl-2.1.29-03.jar:2.1.29-03]
        at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101) [jsf-impl-2.1.29-03.jar:2.1.29-03]
        at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118) [jsf-impl-2.1.29-03.jar:2.1.29-03]
        at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:80) [LifecycleImpl.class:na]
        at javax.faces.webapp.FacesServlet.service(FacesServlet.java:603) [jsf-api-2.1.29-03.jar:2.1]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) [catalina.jar:8.0.23]
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) [catalina.jar:8.0.23]
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.0.23]
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) [catalina.jar:8.0.23]
        at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.web.IdentityFilter.doFilter(IdentityFilter.java:40) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.web.LoggingFilter.doFilter(LoggingFilter.java:60) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:198) [javamelody-core-1.56.0.jar:1.56.0]
        at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:176) [javamelody-core-1.56.0.jar:1.56.0]
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) [catalina.jar:8.0.23]
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [catalina.jar:8.0.23]
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [catalina.jar:8.0.23]
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142) [catalina.jar:8.0.23]
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [catalina.jar:8.0.23]
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:617) [catalina.jar:8.0.23]
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [catalina.jar:8.0.23]
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518) [catalina.jar:8.0.23]
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091) [tomcat-coyote.jar:8.0.23]
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668) [tomcat-coyote.jar:8.0.23]
        at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2463) [tomcat-coyote.jar:8.0.23]
        at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2452) [tomcat-coyote.jar:8.0.23]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.8.0_151]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.8.0_151]
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.0.23]
        at java.lang.Thread.run(Unknown Source) [na:1.8.0_151]
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: defineProjectDetailsBean
        at org.jboss.seam.Component.getInstanceInAllNamespaces(Component.java:2414) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.getValueToInject(Component.java:2366) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.injectAttributes(Component.java:1743) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.inject(Component.java:1561) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:63) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at de.verit.klaros.web.beans.pages.define.list.DefineProjectsBean_$$_javassist_seam_40.init(DefineProjectsBean_$$_javassist_seam_40.java) ~[DefineProjectsBean.class:na]
        at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:144) [jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.callComponentMethod(Component.java:2313) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.callCreateMethod(Component.java:2236) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        at org.jboss.seam.Component.newInstance(Component.java:2196) ~[jboss-seam-2.3.1.SR1.jar:2.3.1.Final]
        ... 80 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: evaluateTestRunDetailsBean
        at de.verit.klaros.web.beans.pages.define.details.DefineProjectDetailsBean_$$_javassist_seam_41.init(DefineProjectDetailsBean_$$_javassist_seam_41.java) ~[DefineProjectDetailsBean.class:na]
        ... 105 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: executeSingleJobBean
        at de.verit.klaros.web.beans.pages.evaluate.EvaluateTestRunDetailsBean_$$_javassist_seam_48.init(EvaluateTestRunDetailsBean_$$_javassist_seam_48.java) ~[EvaluateTestRunDetailsBean.class:na]
        ... 130 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: jobDetailsBean
        at de.verit.klaros.web.beans.pages.execute.ExecuteSingleJobBean_$$_javassist_seam_49.init(ExecuteSingleJobBean_$$_javassist_seam_49.java) ~[ExecuteSingleJobBean.class:na]
        ... 155 common frames omitted
        at de.verit.klaros.web.beans.pages.jobs.JobDetailsBean_$$_javassist_seam_55.init(JobDetailsBean_$$_javassist_seam_55.java) ~[JobDetailsBean.class:na]
        ... 180 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: defineTestCaseDetailsBean
        ... 205 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: evaluateIssuesBean
        at de.verit.klaros.web.beans.pages.define.details.DefineTestCaseDetailsBean_$$_javassist_seam_56.init(DefineTestCaseDetailsBean_$$_javassist_seam_56.java) ~[DefineTestCaseDetailsBean.class:na]
        ... 230 common frames omitted
Caused by: org.jboss.seam.InstantiationException: Could not instantiate Seam component: navigationEvaluateBean
        at de.verit.klaros.web.beans.pages.evaluate.issues.EvaluateIssuesBean_$$_javassist_seam_59.init(EvaluateIssuesBean_$$_javassist_seam_59.java) ~[EvaluateIssuesBean.class:na]
        ... 255 common frames omitted
Caused by: java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key menuEvaluateIssuesItem
        at java.util.ResourceBundle.getObject(Unknown Source) ~[na:1.8.0_151]
        at java.util.ResourceBundle.getString(Unknown Source) ~[na:1.8.0_151]
        at de.verit.klaros.web.beans.navigation.NavigationBaseBean.createDefaultMenuItem(NavigationBaseBean.java:128) ~[NavigationBaseBean.class:na]
        at de.verit.klaros.web.beans.navigation.NavigationEvaluateBean.buildMenuModel(NavigationEvaluateBean.java:139) ~[NavigationEvaluateBean.class:na]
        at de.verit.klaros.web.beans.navigation.NavigationBaseBean.preRenderRefresh(NavigationBaseBean.java:63) ~[NavigationBaseBean.class:na]
        at de.verit.klaros.web.beans.navigation.NavigationBaseBean.init(NavigationBaseBean.java:57) ~[NavigationBaseBean.class:na]
        at de.verit.klaros.web.beans.navigation.NavigationEvaluateBean.init(NavigationEvaluateBean.java:73) ~[NavigationEvaluateBean.class:na]
        at de.verit.klaros.web.beans.navigation.NavigationEvaluateBean_$$_javassist_seam_60.init(NavigationEvaluateBean_$$_javassist_seam_60.java) ~[NavigationEvaluateBean.class:na]
        ... 280 common frames omitted
RE: Update from DB 4.9 to 4.12 fails (Answer)
Jedi Council Member Posts: 771 Join Date: 2/12/09 Recent Posts
Hello Dominic,
thanks for the feedback and the detailed information.
You are stumbling over the issue KLAROS-2615 (After upgrading from 4.2.8 to 4.3.1 upon the first startup, new message properties cannot be found) which has been fixed from Release 4.3.2 onward.
The simple solution is to just restart the Tomcat server, which then should allow you to login.
The log message regarding HHH000388 is harmless and not related to this issue.
I would have expected that a direct update from 4.2.4 to  4.8.4 works out of the box. If you can spare the time, can you please send the related log files to support@verit.de and add some information where exactly the update process failed?
Hope this helps, please let me know if that works.
Cheers,
Hello Torsten, you're right - it worket from 4.2.4 to 4.8.4!
What did not work
I have tried to install version 4.8.4 thru the installation assistent by choosing the same install location as version 4.2.4. Then I got the message "Eine inkompatible Installation wurde erkannt. Deinstallieren sie ...".
What did work fine
I installed version 4.8.4 to another (new) folder and configured the database location with the environment variable KLAROS_HOME. After starting up the website, the database got updated successfully!
Hi Dominic,
thanks, this is great to hear!
The error message you received is rooted in the major IzPack Installer version update we did somewhere between version 4.2.4 and 4.8.4.
The problem you noticed is a known one and covered in the install documentation here: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.html#User-Manual.Installation-Process.Main.Run-Klaros.UpdateProcess.Incompatible-Installation
Have a nice weekend,
