Oracle Database
Jacopo Doria, modified 8 Years ago.
Oracle Database
Youngling Post: 1 Join Date: 5/11/17 Recent Posts
I tried to change the default db from derby to Oracle.
I followed the tutorial I found here (http://klaros-testmanagement.com/en/) but I have always this error message in log file:
2017-05-11 17:53:42: INFO, org.hibernate.dialect.Dialect HHH000400: Using dialect: org.hibernate.dialect.Oracle10gDialect
2017-05-11 17:53:43: INFO, org.hibernate.validator.internal.util.Version HV000001: Hibernate Validator 4.3.2.Final
2017-05-11 17:53:44: INFO, org.hibernate.search.Version HSEARCH000034: Hibernate Search 4.5.3.Final
2017-05-11 17:53:57: WARN, org.hibernate.engine.jdbc.spi.SqlExceptionHelper SQL Error: 1000, SQLState: 72000
2017-05-11 17:53:57: ERROR, org.hibernate.engine.jdbc.spi.SqlExceptionHelper ORA-01000: maximum open cursors exceeded
2017-05-11 17:53:57: ERROR, org.hibernate.tool.hbm2ddl.SchemaUpdate HHH000299: Could not complete schema update
    at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126)
    at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112)
    at org.hibernate.tool.hbm2ddl.DatabaseMetadata.getTableMetadata(DatabaseMetadata.java:158)
    at org.hibernate.cfg.Configuration.generateSchemaUpdateScriptList(Configuration.java:1283)
    at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate.java:237)
    at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate.java:203)
    at org.hibernate.internal.SessionFactoryImpl.<init>(SessionFactoryImpl.java:522)
    at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1859)
    at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1930)
    at org.springframework.orm.hibernate4.LocalSessionFactoryBuilder.buildSessionFactory(LocalSessionFactoryBuilder.java:372)
    at org.springframework.orm.hibernate4.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:454)
    at de.verit.klaros.core.dao.hibernate.KlarosLocalSessionFactoryBean.buildSessionFactory(KlarosLocalSessionFactoryBean.java:68)
    at org.springframework.orm.hibernate4.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:439)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1637)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1574)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1481)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1226)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543)
    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
    at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
    at org.jboss.seam.ioc.spring.ContextLoader.startupContextLoader(ContextLoader.java:64)
    at org.jboss.seam.ioc.spring.ContextLoader.create(ContextLoader.java:43)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:144)
    at org.jboss.seam.Component.callComponentMethod(Component.java:2313)
    at org.jboss.seam.Component.callCreateMethod(Component.java:2236)
    at org.jboss.seam.Component.newInstance(Component.java:2196)
    at org.jboss.seam.contexts.Contexts.startup(Contexts.java:343)
    at org.jboss.seam.contexts.Contexts.startup(Contexts.java:335)
    at org.jboss.seam.contexts.Contexts.startup(Contexts.java:317)
    at org.jboss.seam.contexts.ServletLifecycle.endInitialization(ServletLifecycle.java:143)
    at org.jboss.seam.init.Initialization.init(Initialization.java:813)
    at org.jboss.seam.servlet.SeamListener.contextInitialized(SeamListener.java:36)
    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4853)
    at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5314)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
    at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:753)
    at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729)
    at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
    at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
    at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816)
    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
    at java.util.concurrent.FutureTask.run(FutureTask.java:262)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
    at java.lang.Thread.run(Thread.java:745)
2017-05-11 17:53:58: WARN, org.hibernate.engine.jdbc.spi.SqlExceptionHelper SQL Error: 942, SQLState: 42000
2017-05-11 17:53:58: ERROR, org.hibernate.engine.jdbc.spi.SqlExceptionHelper ORA-00942: table or view does not exist
According to the guide, I set the number of open_cursor to 2000 (even if I think this is an horrible suggestion...), but without any result.
Could you help me?
RE: Oracle Database (Answer)
Hi Jacopo,
This is a bug in the distributed oracle driver (ojdbc7 12.1.0.2.0). See https://community.oracle.com/thread/3682300
Remove the driver webapps/klaros-web/WEB-INF/libs/ojdbc7-12.1.0.2.0.jar and add the attached jar, then restart your tomcat server.
We will change this in the upcoming 4.7.0 release.
