RE: Listening only on local IPv6 address
Robert Gröber, modified 11 Years ago.
Hello
tcp6 0 0 :::18080 :::* LISTEN
robig
test-ubuntu:/opt/klaros$ wget --no-proxy -O - http://10.40.21.62:18080/klaros-web
--2010-05-21 11:49:35--  http://10.40.21.62:18080/klaros-web
Connecting to 10.40.21.62:18080... connected.
HTTP request sent, awaiting response... 400 Bad Request
2010-05-21 11:49:35 ERROR 400: Bad Request.
Heiner Westphal, modified 11 Years ago.
Heiner Westphal
Ive tried to set that property but didn't work emoticon
Same issue as before.
Ubuntu-Forums: Disable IPv6
looks most promising to me.
Best Regards,
Heiner Westphal
Robert,
Hope this helps.
