RE: Java Home JRE Home not defined. - Klaros Test Management - Forum - Klaros Test Management
Avery Jacobson, modified 8 Years ago.
Youngling Posts: 5 Join Date: 5/16/16 Recent Posts
Neither the JAVA_HIME nor the JRE_HOME environment variable is defined. At least one of these environment variable is needed to run this program. That is the message I get when I try to run the startup.bat file. I have no idea what they are talking about. Thanks for the help.
Klaus Mandola, modified 8 Years ago.
RE: Java Home JRE Home not defined. (Answer)
Youngling Posts: 2 Join Date: 2/12/09 Recent Posts
Hi Avery,
thanks for your interrest in Klaros-Testmanagement.
Your Windows system either has no Java Runtime installed or, as the error message states, the Java environment variables are not set.
In the Klaros-Testmanagement documentation you will find information on how to get theses issues fixed.
Information on how to set the system variables:
http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.html#User-Manual.Installation.Prerequisites.Java
Information on how to install Java (if not yet installed):
http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.html#User-Manual.Installation.Prerequisites.Server
Klaus
Klaus
